Old 09-20-2012, 12:24 PM   #1
oneoff
oneoff's Avatar
Transmission cross members?
Looking for an aftermarket transmission cross member for my current build. I'm heading out the door and will have time to search the forum later, however a quick few referrals would make this process quicker.
Putting in an LS series and either 700R4,4L60 and or 4L80, Any recommendations?
Build: http://67-72chevytrucks.com/vboard/s...d.php?t=541803
Dennis H
1969 Chevy C10, SWB, LS3,6.2L engine
1969 Chevy Chevelle SS,BBC, Convertible
oneoff is offline   Reply With Quote
Old 09-20-2012, 12:45 PM   #2
Johnnyfever
Re: Transmission cross members?
I bought a tubular from classic parts of america and it worked great for my application, but I think you need to post this in the correct area of this forum and not in the build section.
Johnnyfever is offline   Reply With Quote
Old 09-20-2012, 01:06 PM   #3
Xeen
Xeen's Avatar
There are a bunch of different companies that make automatic transmission crossmembers.
1) CPP under ENGINE AND TRANSMISSION MOUNTS section, part #cp9427 $79.00
2) ECE has several products for your 700R4 conversion including the cross member-part #912-6372ATXPC $89.00, Overdrive Transmission conversion kit-part #912-700R4 $299.00.
3)GMC Pauls Automatic Transmission Crossmember available in raw steel if so desired, part #653253 $70.00
There are more but these should get you started.
Happy trucking!
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
