Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 07+ Chevy and GMC Message Board
Old 10-28-2012, 10:42 PM   #1
Red68
Red68's Avatar
Load leveling air bags?
I recently had a front leveling kit installed on my 2010 GMC Serria crew cab 4x4. I hooked a trailer on it and loaded my 68 chevy truck onto the trailer and could not believe how low the back squated down. Prior to the leveling kit it basicly leveled the truck so I guess it drops the rear about 2 1/2". Who has used load leveling air bags to raise the rear up when towing a trailer? I found a pair on the internet "steetsideauto.com" Looks really easy to install, just wondering if they work.
Kevin
1968 C10 LWB 327 bored 40 over, RHS heads, KB pistons, Eagle rods, Edlebrock carb & intake
1968 C10 flatbed 307 w/ 4 spd manual (dads old ride)
1936 1/2 tn pickup, 400sb 350 turbo (partially restored)
1949 1/2 tn, needs complete restore (future project)
1969 Chevy impala 4 dr no post (wifes future car)
2010 GMC Serria 4x4 crew, leveling kit
Red68 is offline   Reply With Quote
Old 10-29-2012, 01:03 PM   #2
piecesparts
Parts and more parts
piecesparts's Avatar
Re: Load leveling air bags?
I have a set of Air Lift bags sitting on the floor of my shop for my 2011, but I have not taken on the large amount of brake line and anti-lock equipment that is mounted on the rear axle. I just want the bags to counteract the load due to my lowering the truck.
Frank
piecesparts is offline   Reply With Quote
Old 10-30-2012, 08:20 PM   #3
Pro Performance
Pro Performance's Avatar
I have a set of rear helper bags on my 08 Silverado, and it does help even it out in the rear when I am hauling a heavy load or have a trailer with a lot of tongue weight. I have the Firestone on my truck, but both Airlift and Firestone are great brands.
PS, we can get air helper bags if you need.
Pro Performance is offline   Reply With Quote
Old 10-30-2012, 09:39 PM   #4
Red68
Red68's Avatar
Thanks for the replys. I will check out your website.
Old 10-31-2012, 10:39 AM   #5
vin63
It's Better With Nitro
vin63's Avatar
While not the same model year as yours, I have used Hellwig (at the time used Firestone air springs) rear air load control systems on previous duallies ('88 and '95) with very good experience (towing my race car trailer). It really helped stabilize varying loads - some of the races further away, I carried more equipment, etc.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
