Old 10-30-2012, 12:59 AM   #1
1984SILVERADO
1984SILVERADO's Avatar
Different length intake bolts???
Okay I am replacing my intake gaskets on my 78 5.7L 350 motor, it has the stock intake manifold. I got the bolts mixed up and I am not sure where they go. I know there is 3 long bolts and 3 short bolts on the left side. The right side has 2 long bolts (which one of the long one goes through the bracket back by the distributor and four short bolts. My manual doesn't say anything about the location of them.
1984SILVERADO is offline   Reply With Quote
Old 10-30-2012, 07:08 AM   #2
xrcr
Re: Different length intake bolts???
Can you look at the intake and figure it out. What I mean is is there more material or a "step up" where certain longer bolts would go and likewise are there "recessed" holes that would require shorter. You can run them in and see if they bottom or not. I haven't looked at a stock manifold in awhile.
Good Luck
xrcr is offline   Reply With Quote
Old 10-30-2012, 04:45 PM   #3
Desert1957
Desert1957's Avatar
There are some intake holes that if along bolt is installed will lock down the pushrod. If memory serves its the holes around # 3,4,5,6 intake.
Desert
Desert1957 is offline   Reply With Quote
