Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 11-01-2012, 08:42 AM   #1
ChevyNewb
ChevyNewb's Avatar
Next Step
So we put in the USA-230 system with the kick panel speakers. Unit sounds OK, if a little hollow? We are definitely missing something in the low end. What should our next step be? Would a sub work in the old factory speaker hole in the dash? Sub under the seat? Would like to stay in the "do it yourself, cheaply" area.
'68 Longbed Stepper. Mango Tango
ChevyNewb is offline   Reply With Quote
Old 11-01-2012, 12:15 PM   #2
jimmydean
jimmydean's Avatar
Re: Next Step
Do it yourself cheap would be a powered bass tube. Easy to install, no real hardware, just input/power/ground and it will add some bottom end real nice.
I'm not a huge fan of bass tubes, but a few friends with trucks (like my off road buddies) love them because you can pull them out easy enough.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 11-14-2012, 02:23 AM   #3
rafaelsmall94
rafaelsmall94's Avatar
Re: Next Step
Bass tubes are good if you want an immediate solution. I installed them and they just seem to work fine.
rafaelsmall94 is offline   Reply With Quote
Old 11-14-2012, 03:28 PM   #4
tubbedII
needs more $$$
tubbedII's Avatar
Re: Next Step
I too am not a big fan of them...but, my uncle had an 8" tube in his toyota ex-cab and it fit his needs just fine. Actually, it sounded pretty good for what it was.
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 11-14-2012, 07:53 PM   #5
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Re: Next Step
Yea bass tubes aren't bad there fairly cheap and install easy. Depends on what your looking for and how much time and money you want to spend. A good sub under the seat would probably be louder but more time and money as well. Good luck which ever way you go.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 11-15-2012, 04:41 PM   #6
ChevyNewb
ChevyNewb's Avatar
Re: Next Step
think for the time being we will just find a decent bass tube. gotta get something in that low end...just aint cuttin it
thanks for the info
Old 11-17-2012, 02:21 AM   #7
rafaelsmall94
Re: Next Step
Yeah ChevyNewb. Get a decent bass tube because things which are worth having are worth waiting for.
Best cheap trucks for sale, never before deals.
Old 12-01-2012, 08:30 PM   #8
mrhino
Re: Next Step
sound deadener really helps that hollow or tinny sound.
mrhino is offline   Reply With Quote
