11-22-2012, 12:41 PM | #26 |
Re: my first paint job
Only 45, I bet your beard isn't even completely grey yet. And happy 55 to MLB57, nice job on that paint. I'm in the middle at 50, but I'll probably be at least 55 by the time I get any actual color on my truck.
------------------------------- '66 GMC Custom Fenderside LWB '90 IROC - L98 '97 1200C Sportster |
11-22-2012, 01:02 PM | #27 |
nice p-job--took longer to setup than paint---It's all in the prep as Jim say's, and yes he has given me many a TIP--got you all beat 5-23-49 hope to have paint on mine while i can still drive---Happy T Day everybody
1961 chevy K10 my build is------------61K10 build |
11-22-2012, 11:40 PM | #28 |
I don't have a beard, never been able to grow one I don't have hair on my legs either for what it is worth. MLB 57 lets see tips for wetsanding, dishwashing liquid in with the water to help the paper slide across the top of the surface and not to dig into it. soak you paper a while before using at least a half an hour so that the paper has time to loosen up. If at all possible wrap the paper with a rubber squegee from the parts store they have a soft version and a hard one these serve two perposes one , when the paper is wrapped in this it will not leave finger waves in the surface like wetsanding by holding the paper in your hand and leading it with your fingers. The other way to use this thing is to wipe down the panel as you sand to check progress as you go say removing a run or orange peel while sanding wipe away the soapy water[ yes put soap in the water you use to sand with as well, you know the sliding thing] that way you don't remove more that needed. Also criss cross patterns please!!lets say your gonna start 1200 grit go lower left to upper right. Then wipe that down clean it up and move to the 1500 just after the largest of the imperfections are gone[ie;runs orange peel, thrash,so forth]the 1500 will remove the scratches left by the 1200 grit. Colorsanding is a pain in the rump but it is also very rewarding so take your time be really careful on the corners and good luck to you . Jim
11-23-2012, 01:40 AM | #29 |
Home Built '87
Very NICE job!!!!!
Gordon 1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424 1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833 Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969 |
12-09-2012, 05:21 AM | #30 |
Hmmm, I might have to look you up when I need a paint job. Looks great
Scott |
12-09-2012, 10:37 AM | #31 |
That looks fantastic! Love the color. Do you mind if I ask what paint you used? Did you have the color matched, or did you order from a color chip?
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
12-09-2012, 12:33 PM | #32 |
I used omni MBC base, omni 161 clear and the white is gm3800 DBU. The had they had the paint code mix for that year and color at the ppg store if that makes sense.
12-12-2012, 02:38 PM | #33 |
Good to know. Thanks!
10-19-2013, 08:17 PM | #34 |
thought I would post some pics of some progress
10-19-2013, 08:20 PM | #35 |
Second Chance Program
Looking amazing!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt. 77 C20 crew cab Silverado. 396/th400. In work. |
10-19-2013, 09:00 PM | #36 |
fantastic work looking very nice
JZ
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
08-14-2016, 04:47 PM | #37 |
its finally done after a lot of grief and big mistakes
08-14-2016, 08:41 PM | #38 |
Did you have adhesion issues? What was the issue?
08-14-2016, 09:42 PM | #39 |
switched epoxy brand because it layed out flatter but that omni did not play well with the dupont pulled off some tape after a couple days and it peeled up,
08-14-2016, 09:48 PM | #40 |
forgot to thank everyone for all there help and advice didnt listen when it came to switching products
08-15-2016, 01:01 AM | #41 |
So you were using dupont epoxy and omni base? Trying to figure what went wrong so I don't have the same thing happen to me! On my paint job I used southern polyurethane epoxy and clear and Wanda base and haven't had any problems with it so far.
08-15-2016, 09:50 PM | #42 |
paint store said did not let it flash long enough. one thing i have learned is to follow the flash times so who knows what happened. wish that it would have done it before i had it assembled had it masked off working on the tailgate and started coming off when i took the tape off its done so that all that matters.
08-16-2016, 02:58 AM | #43 |
that sucks! looks great now though!
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
08-16-2016, 05:50 AM | #44 |
Crazy. Sure looks good!
Thread Tools | |
Display Modes | |
