11-24-2012, 04:18 PM | #1 |
1970 Daily Driver
HEI wire
So my dad and I put an HEI on my 70 SWB when I was 5 years old. 25 years later I started having HEI problems. This truck has been my daily driver for the last 15 years. I went ahead and put a brand new Distributor in the truck. That is when I noticed this, see picture below with large to small wire splice.
Is this bad? What do I need to do, run thicker wire? Why has it ran fine for the last couple decades like this? Here is a link with pictures of my new distributer and engine bay http://67-72chevytrucks.com/vboard/s...d.php?t=551274
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance. Last edited by lts70; 11-24-2012 at 04:33 PM. |
11-24-2012, 04:50 PM | #2 |
Re: HEI wire
It looks like it is hooked to the resistor wire. That is not good but I have seen them run like that before. I go in back of the ign. switch & scrape soom insulation off the pink wire. Then solder a 12 gauge wire to it & run it to the bat side of the HEI. Lots of guys hook it to the unfused outlet on the fuse block but I like the direct hookup.
11-24-2012, 04:51 PM | #3 |
Re: HEI wire
You need to run a new lead (probably 12 gauge or better, not sure) right from that distributor all the way to the "IGN UNFUSED" terminal of the fuseblock.
It'll run as is, probably, but you'll get a lot better spark energy if it doesn't have to fight the resistance that was built in to protect the old breaker points.
11-24-2012, 05:05 PM | #4 |
1970 Daily Driver
Re: HEI wire
What is the resistor wire for? Looking at it closer the same color and size of wire comes out of the wire harness at the same place as the one in the picture comes from. Only it is pluged into my electric choke on my edelbrock carburator. If you look hard y.ou can actualy see it in the picture hugging the bottom of my valve cover.
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance. Last edited by lts70; 11-24-2012 at 05:20 PM. |
11-24-2012, 05:24 PM | #5 |
Grandpa in the rustmobile...
Re: HEI wire
I think the yellow wire is for the points setup. Ive read on here it doesnt supply a full 12volts. Like said before run a wire from ignition unfused on the fuse box
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
11-24-2012, 06:04 PM | #6 |
1970 Daily Driver
Re: HEI wire
How has it ran like that for so long, and continues to run?
I am definalty running a new wire. Should I just cap the old wire?
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance. |
11-24-2012, 06:27 PM | #7 |
Re: HEI wire
The resistor wire is for points ignitions only. I believe it is there to limit the amount of current that passes through the breaker points.
11-24-2012, 07:04 PM | #8 |
1970 Daily Driver
Re: HEI wire
Would this cause my truck to stumble a bit on take off?
What kind of problems or symtoms would this bad connection cause?
11-24-2012, 07:58 PM | #9 |
Re: HEI wire
Hard to say. I'd expect it would have the most problems, if they were related to spark energy, at peak torque under max load, because that's when its hardest for the spark to jump the gap.
I wouldn't look for a reason to fix it, just fix it. If it solves the problem, great! If not, at least its correct now and it rules it out. It'll only take a few minutes to do it right.
11-24-2012, 08:32 PM | #10 |
Re: HEI wire
once fixed you will notice a differance before I did the bigger wire in the kids truck it seemed too run very sluggish and I didnt understand why. I ran the big wire into the fuse box and boy what a differance especailly when it was wound up for fun
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
11-24-2012, 08:50 PM | #11 |
1970 Daily Driver
Re: HEI wire
I am not looking for a reason not to do it. I like little projects like this that may improve preformance at no cost
I was just courious because this is the second truck I have had this motor in and I just cant get it to not stumble out of the blocks in this second truck. I am reaqly hoping this is the cause.
11-24-2012, 09:47 PM | #12 |
I am a Referee of life.
Re: HEI wire
http://67-72chevytrucks.com/vboard/s...ad.php?t=17403
http://67-72chevytrucks.com/vboard/s...d.php?t=148346 These threads will help you wire it like factory.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
11-24-2012, 10:21 PM | #13 |
Re: HEI wire
If the resistor is still in the circuit you are not getting 12 volts to the distributor. I did the same thing on my 70 model earlier. Used the same wire just removed the resistor. Soldered the connections and it works fine. I also found out that if you run points and not the resistor you will be stranded soon. Thus my change to HEI
11-24-2012, 11:46 PM | #14 |
1970 Daily Driver
Re: HEI wire
Thanks for the links Paneldeland, very good write ups. I am going to get the new fire wall wire harness connector and re-run thicker gauge from there to the cap.
11-25-2012, 02:37 AM | #15 |
1970 Daily Driver
Re: HEI wire
It looks like one of my yellow (old points) wire feeds is running my electronic choke. Should I leave it be or run it from a different location and wire?
11-25-2012, 03:47 AM | #16 | |
Msgt USAF Ret
Re: HEI wire
The choke also requires a full 12 volts to work and it is hot all the time when the key is on, otherwise the choke will not work properly.The spring will not open the choke and the engine will run rich. You can run the choke off the other ign unfused terminal but do not wire it to the ignition wire that goes to the distributor. Any other key on 12 volt source will work as well, as long as it will support 10 amps or more.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
11-25-2012, 04:52 AM | #17 |
1970 Daily Driver
Re: HEI wire
When I get home from the inlaws I need to tear into my wire harness, because I know both wires have juice to them while the truck is running. I know this because the wire going to my HEI has always kept the truck running and the other wire going to my choke came unpluged when I was timing the new HEI. When it came off it arked sparks on my valve cover and killed the truck.
11-25-2012, 11:26 AM | #18 |
Msgt USAF Ret
Re: HEI wire
Well it sure sounds like you are feeding the HEI off the resistor wire and maybe the choke as well. I would certainly feed the distributor off the fuse panel or the ignition wire at the key switch like wrenchbender does.
Before you do the rewire you could run a temporary wire from the battery plus terminal to the BAT on the distributor and see how the engine runs. Don't leave it on because it isn't switched and will run down the battery or maybe damage the distributor. Maybe you should go ahead and rewire the distributor and choke because you will have to do it anyway.
11-25-2012, 02:37 PM | #19 |
1970 Daily Driver
Re: HEI wire
That's the plan. I am going to unwrap my wires going back to the firewall and see exactly what is going on, mostly because I am curious about what is going on. I will then rewire both the HEI and choke.
Thanks for all the help guys! Posted via Mobile Device
11-25-2012, 04:06 PM | #20 |
Re: HEI wire
subscribed
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, all stock, Survivor. |
11-29-2012, 12:05 AM | #21 |
1970 Daily Driver
Re: HEI wire
Well I peeled back my wiring harness and found that I have been running my HEI and my choke on the low voltage resistor wire. Sure enough it was the white braided wire that broke of into the two yellow wires. See pictures.
11-29-2012, 12:25 AM | #22 |
1970 Daily Driver
Re: HEI wire
I am going to pick up some 12 gauge pink wire tomorrow. When I mesured out the original wire it looks like I will need exactly 6 feet.
I would like to pick up the original style conector and conector shroud for the conection at the HEI (See Picture). I tried to pry the old one open in an effort to possibly reuse but it was to brittle and cracked. Anyone know a part number for these?
11-29-2012, 12:34 AM | #23 |
Re: HEI wire
Just run a new wire from the Ign terminal on the fuse block,,I left my resistor wire in place just in case I ever run points again and ran a new wire for the HEI and it runs Great!
11-29-2012, 01:02 AM | #24 |
Re: HEI wire
11-29-2012, 01:04 AM | #25 |
1970 Daily Driver
Re: HEI wire
I am trying to clean up stray wires. I bought a new firewall wire harness conector and will tap in to the exact location the points set up came from. I know that I will never go back to points so might as well cut out what I dont need and keep things as tight as possible.
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance. Last edited by lts70; 11-29-2012 at 01:28 AM. |
