Old 11-27-2012, 01:15 AM   #1
str8tsix2
str8tsix2's Avatar
transplant '62 235 I6 front motor mount
Hello, I am pretty new to posting, but I need help. I am swapping out the torsion bar front crossmember of my 62 c-10 for a '72 crossmember. I am hell bent on keeping my 235, but my problem is mounting it. The current mount is in the front rivited to the crossmember. I drilled out a donor mount from a 62 in the junk yard to bolt to the 72 crossmember. Has anyone out there tried this? Are there clearance issues i should be looking for? Thank you for any help or suggestions. I'm trying to map it out before I'm half way into it and stuck.
str8tsix2 is offline   Reply With Quote
1962, c-10, crossmember swap, inline 6 chevy c10, motor mounts
