11-27-2012, 08:27 AM | #1 |
cowl screen
was there ever a factory cowl screen for 67-72 trucks?
11-27-2012, 10:24 AM | #2 |
2WD Jimmy
Re: cowl screen
No
11-27-2012, 10:28 AM | #3 |
I am a Referee of life.
Re: cowl screen
Sure was,but it is an aftermarket factory......
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
11-27-2012, 10:54 AM | #4 |
Re: cowl screen
11-27-2012, 11:43 AM | #5 |
Re: cowl screen
No, but some of the aftermarket companies make them. I think they're kinda pricey though.
71 K20 64 GMC mud truck |
11-27-2012, 12:03 PM | #6 |
Florida Edition
Re: cowl screen
Got mine from LMC, very well made and not much $$
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
11-27-2012, 12:17 PM | #7 |
Re: cowl screen
11-27-2012, 12:22 PM | #8 |
Re: cowl screen
thanx folks<<<
11-27-2012, 12:40 PM | #9 |
Re: cowl screen
Happy with mine it works fits right and made of stainless. Forgot the cost I think no more then fifty bucks from LMC. It won't keep out pollen, dust or dirt the fine stuff so it can't hurt to vacum out the vents or take a nice cruise down the highway with the vents open.
11-27-2012, 08:41 PM | #10 |
Re: cowl screen
i made my own using gutter guard.
1968 chevy c10 lwb, 250 inline6, 4 speed, |
11-27-2012, 08:52 PM | #11 |
Old member
Re: cowl screen
I took the cowl off flipped it over on a blanket and hot glued screen porch mesh on it. It's the reinforced kind form Lowes. Been in place for about 5 years now. Once you install the cowl it will hold itself in place. I already had the screen so about $10.00 maybe in cost.
11-27-2012, 09:47 PM | #12 |
Re: cowl screen
Aftermarket stainless ones were $35 or so when I did mine about 6-7 years ago.They came in blck PC also.If you clean the cowl/vent area well during install and make sure the drains are clear,you should never have a problem with needing to clean the vents.The raincarwash/hose flowing thru the cowl should flush anything that will pas thru the screens.
11-27-2012, 10:31 PM | #13 |
Re: cowl screen
I'm thinkin' I might try that. . .looks like an economical solution.
- Jim - My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10 and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911 |
11-28-2012, 04:13 AM | #14 |
Old member
Re: cowl screen
It has done the trick for me. You could use some small duct tape to hold in place also I guess. The hot glue is a little longer lasting though!
11-28-2012, 06:25 AM | #15 |
Re: cowl screen
I bought a roll of hardware cloth several years ago for $7 and so far I have done 9 of our trucks. I cut the material approximately 4" wide and just long enough to cover the existing holes in the cowl. After painting flat black, I use dum-dum to hold it in place while installing the cowl. Once in place the cowl holds the screen and the one row of screws goes through the mess so it can't move.
The screen I use is 1/4" mess and is galvanized. Plastic screen is available, also. The first one was installed in 2002 and still is in good condition. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
11-28-2012, 06:36 AM | #16 | |
Re: cowl screen
12-19-2012, 02:31 PM | #17 |
Re: cowl screen
Thanks for the info guys
Mika |
10-26-2015, 06:48 PM | #18 |
Re: cowl screen
I didn't do the stick the screen to the cowl panel. I cut mine in to fit the cowl/wipers/washers. We'll see how it fares.I used aluminum gutter screen and painted it before assembly. Hopefully it will keep the big stuff out.
It builds on my intelligence when I make a mistake, Boy am I building on it! '67 C-10,'70 Nova SS |
10-26-2015, 06:55 PM | #19 |
Re: cowl screen
I plan to use the same mesh that I will use in the grille
"Hey... its only time and money right? Just do it." 67 Short Bed under major construction http://67-72chevytrucks.com/vboard/s...=651356&page=8 |
11-04-2015, 07:14 PM | #20 |
Re: cowl screen
FYI.I just installed a cowl seal from Wes at Classic Heartbeat. Nice seal(Precision). I see now why you would glue the screen to the cowl panel. I had to remove the whole cowl panel again! To install the seal!
11-04-2015, 07:18 PM | #21 |
Re: cowl screen
I was just wondering about a cowl screen when I saw this thread! What timing!
11-04-2015, 08:27 PM | #22 |
Re: cowl screen
I bought either the Brothers or LMC black version. It's holding up well and looks great I think.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
11-04-2015, 08:32 PM | #23 |
Re: cowl screen
This is what I used aluminum gutter screen. painted to keep the different metals from reacting!!
11-04-2015, 08:34 PM | #24 |
Re: cowl screen
I should add. $2.49 at Lowes for 20 feet.Plenty of screwups! LOL!
11-04-2015, 08:37 PM | #25 |
Re: cowl screen
My bad Menards!!.I'm not a Jimmie Johnson fan! HA! LOL
