Old 11-27-2012, 02:05 PM   #1
72sbchevy
Question dana 44 front 6 to 8 lug conversion
I am doing a 6 to 8 lug conversion up front and have a few questions.
1. Can i use the same spindles ?
2. can i use the same warn gold premium i used for the 6 lug?
72 c10 frame off- put on hold
72 cheyenne 20 super -under construction
72 k10 short bed 6 inch lift- under construction
79 gmc 1 ton 4x4 plow truck
72sbchevy is offline   Reply With Quote
Old 11-28-2012, 02:07 PM   #2
CrewCab59
CrewCab59's Avatar
Re: dana 44 front 6 to 8 lug conversion
1.Yes
2.Yes
As long as your using 77-91 D44 corp 10 parts to do the swap.
1972 Custom Deluxe 20 4x4 burb
1971 GMC SWB CST 4x4
1972 GMC k20 4x4 (X- brush truck )
1971 Chevy CST Blazer 4x4
1971 Chevy C/10
1970 Cab Chassis C30 157"
1971 Cab Chassis Custom 30 Deluxe 157" 292/4spd ( Napco Replica )
1988 Chevy V30 4x4 wrecker challenger 4812
CrewCab59 is offline   Reply With Quote
Old 12-01-2012, 06:58 PM   #3
72sbchevy
so i would have to use the spinles from those years to do the conversion, this is a 72 d44
Old 12-01-2012, 08:06 PM   #4
CrewCab59
CrewCab59's Avatar
Yes , your 1/2 spindles are the same as the 77 and up D44 and corp 10.
The pre 76 are big hub D44 and can't mix match those parts.
1971 Chevy C/10
3/4 ton 4x4 axle swap, 4x4, dana 44
