Old 11-30-2012, 07:32 AM   #1
olskool68
'58 king pin thrust bearing assembly
I've seen the instructions provided by speedway motors on another post, and it doesn't mention anything about a metal washer between the two brass thrust washers. It reads to me that the two brass faces face each other.
http://static.speedwaymotors.com/pdf/910-32130.pdf
But the repair manual mentions the metal washer and a build featured in Classic Trucks mag showed it that way.
Reason I ask is because when I went to rebuild my spindles on my 58 3200, the fit was WAY tight with the metal washer between the two brass washers. Looking at the old ones that I removed, there was nothing between the brass thrust bearing. Short question long, do I need that metal washer?
Struck down, but not destroyed 2 Cor 4:9
1958 Apache 32
olskool68 is offline   Reply With Quote
Old 04-11-2020, 12:16 PM   #2
cansled
Re: '58 king pin thrust bearing assembly
I know this is quite an old post but this is not been answered and is a question that I have as well. The manual says there's a thin washer between the two brass washers but it does not state that in the speedway directions or shown on the Brothers trucks video on their website
cansled is offline   Reply With Quote
