Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork > Detailing
Old 12-05-2012, 03:29 PM   #1
ChevyNewb
ChevyNewb's Avatar
Door Panel Recovering
So we have just plain metal that we rattlecanned. Not bad. Stumbled across some leather material in the dumpster! Anyone have luck with recovering the panels? Just glue to the backside then screw down?
Any insight or tips would be awesome!
'68 Longbed Stepper. Mango Tango
ChevyNewb is offline   Reply With Quote
Old 12-06-2012, 06:24 PM   #2
piecesparts
Parts and more parts
piecesparts's Avatar
Re: Door Panel Recovering
I would consider a thin layer of closed cell foam between the leather and the metal panels to give a little forgiveness to the leather. If you glue it directly to the metal there will be wear and pinch points that the leather will wear through quickly.
Frank
piecesparts is offline   Reply With Quote
Old 12-07-2012, 11:12 AM   #3
ChevyNewb
ChevyNewb's Avatar
Good call on the foam. I am sure that is easier to attach to the backside as well...
Old 12-07-2012, 05:40 PM   #4
piecesparts
If you have time, then get some Weldwood Contact cement and coat the panel and the foam. Place the foam and trim to the edges of the panel leaving a small amount to allow the leather to pull in tight to the metal panel. When you put the leather on, use the contact cement and stick it to the foam, then stick it to the metal panel after the surface glued to the foam is dry to be sure that you get a good tight stretch of the cover material.
Frank
Old 12-10-2012, 12:46 AM   #5
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
have you thought about doing some hydrographic transfer film ,i took my panels and sandblasted them clean and had them graph film applied ,the print is skulls and smoke
there's a ton of different prints out there
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 12-22-2013, 01:26 PM   #6
BC10
BC10's Avatar
That is wicked! Do you have any more info or links? Thanks
BC10 is offline   Reply With Quote
Old 12-25-2013, 11:31 PM   #7
SACRAMENTO 71
SACRAMENTO 71's Avatar
68 C10 SWB W/ 72 FRONT CLIP 343SB TH400
64 C10 SWB 406SB TH400
74 SUBURBAN 454BB TH400
78 K10 SWB 350 TH350 6" ON 35" BFG MUD
71 K5 350 W/ TBI 700R4 6" ON 38" BFG MUD
00 K3500 DRW BIG BLOCK "DRINKING PRBLM"
SACRAMENTO 71 is offline   Reply With Quote
Old 12-25-2013, 11:50 PM   #8
franken
I haven't tried it, but maybe shoot the back w/ 3M or whatever undercoat to damp noise?
franken is offline   Reply With Quote
Old 12-26-2013, 08:43 PM   #9
calvin78612
calvin78612's Avatar
Go to youtube and type in hydrographic film.
84 step side
87 swb
calvin78612 is offline   Reply With Quote
