Old 12-17-2012, 09:53 PM   #1
JAG66
Charging System Failure 2005 Z71
Started my 2005 Z71 to leave work, "charging system failure" displayed. Lights dimming, wipers getting slower, gauges stop working as volts gradually dropping from 14 to 9. Truck finally stops running at stop sign. All this happened within about 8 miles of driving.
My first thoughts are alternator.
After about 20 minutes tried to start, and click, click sound, like a dead battery.
Receive a jump start and drive 1 block to Advance Auto. Gauge showing 14 volts.
Charging system check performed at Advance and battery and alternator all good.
Turn off truck, truck starts right up and holding steady 14 volts.
Drive home with no charging system issues. But no confidence in driving to work tomorrow.
Any ideas? Anyone had this "charging system failure"? What else should I look for?
Thanks, Jeff
JAG66 is offline   Reply With Quote
Old 12-18-2012, 08:19 PM   #2
clinebarger
Re: Charging System Failure 2005 Z71
I would guess Alternator. Do this test the next time it acts up........Check the voltage at the Output post.......If below above 13.5, Perform this test.......
Disconnect the regulator plug with the engine running, Check the voltage on the Brown wire, If it has above 2.5 volts........Replace the alternator.
clinebarger is offline   Reply With Quote
Old 12-20-2012, 12:17 AM   #3
JAG66
Even though intermittent, sure walks and talks like an alternator issue, so changed the alternator. Everthing fine now. (fingers crossed)
