Old 12-18-2012, 07:49 PM   #1
vannatta20
vannatta20's Avatar
My Efi tank solution
Boyd's tank for 350$ plus a used ls1 pump for 35$ off eBay.
vannatta20 is offline   Reply With Quote
Old 12-18-2012, 07:57 PM   #2
vannatta20
vannatta20's Avatar
Re: My Efi tank solution
The ls1 pump assembly has a built in fuel regulator for a returnless fuel system. I removed it since my system had a return and used a basic 3/8 to 3/8 10$ fuel filter.
Old 12-18-2012, 08:58 PM   #3
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Check to see what pressure that ls1 pump puts out, for the Lsx, you need 58psi at the rails
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 12-19-2012, 12:01 AM   #4
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
my external setup has worked fine...but if/when it fails I've thought about doing something like this.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 12-19-2012, 12:57 AM   #5
vannatta20
vannatta20's Avatar
My truck has a fuel regulator on the fuel rails. That's why I removed the fpr in the pump.
Old 12-19-2012, 01:10 AM   #6
coyotes33
coyotes33's Avatar
So you have a return style fuel rail? if so how do you have your fuel lines set up?
coyotes33 is offline   Reply With Quote
Old 12-20-2012, 11:08 PM   #7
vannatta20
vannatta20's Avatar
Yes, I have a return from the fuel rail. I just run the return to the pump return. Pump feed to a cheap filter to the intake feed.
Old 12-20-2012, 11:15 PM   #8
coyotes33
coyotes33's Avatar
Do you have a list of the items you used for it and any pics?
Old 11-23-2017, 11:53 PM   #9
vannatta20
vannatta20's Avatar
Dorman 800-075 that will be the feed 3/8 line
Dorman 800-074 5/16 return line
Dorman 800-075 5/16 fuel fittings
Dorman 800-082 3/8 Fuel Line Fitting
Motorcraft FG1083 Fuel Filter 3/8 push connect ( may be wrong its been awhile) also this is only a filter. it does not regulate fuel pressure
Spectra Premium TR7 Fuel Tank Lock Ring
Total is about 60$ so not bad for the parts listed above. The fuel system will cause the most headaches in a LS swap. Either spend big bucks for a aftermarket setup or piece together a OEM setup in my opinion. Anything else can be a gamble. I have had every external fuel pump fail. Not worth it. Every customer has had their external pumps fail within 6 months. I know some others have had better luck but it is not worth the headache and stress.
If you need a regulator for a none return system get this
WIX Filters - 33737
New AC delco Pump https://www.amazon.com/ACDelco-Assem...1%2C3937584011
Old 11-24-2017, 01:21 PM   #10
71Charlie10
thats exactly what im doing! i havent figured out how to install the factory locking ring yet. Can you post a close up picture of yours? How did you secure the locking ring?
thanksd
71Charlie10 is offline   Reply With Quote
Old 11-24-2017, 01:33 PM   #11
vannatta20
vannatta20's Avatar
I don't have a pic but we just drilled and tapped the tank for small screws to hold the lock ring tight. The aluminum is thick enough. If it is stainless steel then that wont work.
Old 11-24-2017, 01:40 PM   #12
71Charlie10
i gotchya. thanks for getting back to me
