Sub works, all others silent.
Just did a motor swap. All speakers (6 plus sub) were working before the swap.
Now, only the sub box can be heard. I have an equalizer, two amps, and a Pioneer head. Any ideas??? Thanks in advance for the help, Tim Posted via Mobile Device
"It is, what it is" K5 NV ![]() 71' Blazer CST 84' GMC Jimmy-SOLD 2008 Suburban LTZ |
Re: Sub works, all others silent.
check, check, and quadruple check all of the connections. Make sure nothing is backwards and that all your grounds are actually grounded haha. That is always my first step.
Will 1968 C10 - Project Texa Go 6.0/4L80e 2003 Mitsubishi Lancer Evolution 2002 Ford Excursion 7.3L 2024 Toyota Sienna |
#3 | |
Thanks Billett. Grounds do need checking. Posted via Mobile Device
I know it's not necessarily the most useful advice and definitely tedious, but you never know. It's better than pulling your hair out later for something so simple.
#5 | |
I will have time this weekend and post my find. Thanks, Tim Posted via Mobile Device
needs more $$$
Check the power wire too. Are your amps wired to junction blocks with seperate fuses?
1970 2wd Blazer |
#7 | |
I have never checked. I will also check that this weekend. Thank you, Tim Posted via Mobile Device
