01-13-2013, 08:18 PM | #1 |
How can I get a temp. gauge?
My truck's dash is sorely lacking in instrumentation. I have a speedometer, fuel gauge, an idiot light marked generator and an idiot light marked oil pressure. What I would like is at least a temp. gauge, maybe even oil pressure and volts. The fuel gauge is quite large and looks like could have extra marks in it. Did some of the nicer trucks have a combination type gauge instead of just a large fuel gauge? If I can get a factory temp gauge what am I looking for? I know the engine already has a temp. sensor on it but it isn't wired to anything.
1987 S-10 Blazzer Sold, 1986 GMC Jimmy Sold, 2002 Chevy 2500 HD 2wd, 6.0, auto. Sold, 2007 Chevy 3500 SRW 4wd D/A Sold, 2005 Chevy 3500 4wd CC, D/A, dually, 2001 Chevy 3500 4wd EC, 8.1/A dually, 1969 Chevy C10 short bed, 307 V8 |
01-13-2013, 08:22 PM | #2 |
Moderator
Re: How can I get a temp. gauge?
You can probably find a nice full gauge cluster for sale on the parts board here.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
01-13-2013, 08:43 PM | #3 |
Old member
You could get the full cluster off the boad more than likely but you will need to change the wiring harness to make it all work. The connector on the back of the dash has to be redone because some of the wires are in differant spots in the connector.
Here is a link for you. http://67-72chevytrucks.com/vboard/s...ad.php?t=18867 If you want aftermarket's you could use the little three guage cluster sold at most part stores. They come with everything you need. Cut the dash and mount them in the bottom are use the mount they come with.
01-13-2013, 08:58 PM | #4 |
That temp sensor goes to a light marked "temp" in the lower corner ogf the gas gauge.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
01-14-2013, 12:11 AM | #5 | |
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
