Starting 250 after sitting a long time
I'm hoping to start my 67 250 this weekend that has been sitting for 3 years or so. I got it from my Dad, and he doesn't have any idea when the oil was last changed. Last weekend, I emptied the fuel tank and put a new carb on (the old one was physically broken, leading to it being parked), and made sure the engine would turn.
Before I try and start it, I'm thinking that I should change the oil, and probably drop the pan and clean it out. I don't have an oil priming tool, is there something I should do to get oil back up into the engine before I try and start it? Any other advice? I'm planning on keeping this engine in it at least a couple more years, so I'd prefer to not tear it up.. |
Re: Starting 250 after sitting a long time
Brian, welcome to this forum! Pull the plugs and start by spraying a good amount of PB Blaster into each cylinder, reinstall plugs and let her sit for a few days. Pull valve cover off and check all valve train rockers to see that they are free, pour a little oil down all pushrods. I have started many GM 6cyl's that had sat for years with no major issues, just go slow and make sure the engine is free. If you pull the distributor to prime the bottom end , be sure you take notice of rotor position and mark the location of distributor body to replace it in proper location.....Good Luck
![]() Posted via Mobile Device
71 C-20 07 Magnum RT AWD |
#3 | |
![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() Last edited by Ironangel; 01-15-2013 at 01:47 PM. |
Active Member
![]() Join Date: Jul 2007
As mentioned above, I did the plug removal then I used a small oil pump filled with regular 10W30 and squirted a few times in each cylinder. Cranked engine for several revolutions, reinstalled plugs and started engine.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
