Old 01-19-2013, 10:14 AM   #1
Smokeater88
4-6 drop question
I am new to lowering trucks all the suspension work I have done is to lift trucks for off road. I have a 72 chevy c-10 LWB. I have the bed off for body work and want to do a boyd tank between the frame rails any advise on what tank to buy (side fill top fill, any other parts needed, or modifications to make it fit)? and can I do a 4-6 drop with that tank. I have seen posts about guys with a 4-6 drop with out notching the frame. I am thinking about the ece kit unless someone knows a more budget friendly kit. This truck is just for cruising so I wont ever be loading the bed or towing. Any input will help I am very new to this.
Smokeater88 is offline   Reply With Quote
Old 01-19-2013, 10:40 AM   #2
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
Re: 4-6 drop question
I have a 68 swb with a 4.5/6 drop from ECE and I am using the Boyd tank. I used the bed fill because I didn't want to do the work to put filler access in the side of the bed. Many people here on the board have used the side fill with great success, but it is a good bit of work. Also, I do not have a notch, I just trimmed the bump stops. I plan to notch mine for extra clearance, but it is not a necessity. Hope this helps, and good luck with your build!
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 01-19-2013, 10:41 AM   #3
clemsonteg
With the reading I've done, it seems like the shorty guys say they can get by with the 6 in the back and no notch. The long guys I have seen mixed comments. I think with the added weight of the fuel tank and fuel behind the wheels, leverage may not play in your favor.
clemsonteg is offline   Reply With Quote
Old 01-22-2013, 04:26 PM   #4
Smokeater88
Thanks for the info guys. BucksSS how did you do your bed fill. Did you put in a filler door or a marine cap? any advice for the install or pics. I guess I will try the drop kit and if I need a notch thats just another excuse to work on the truck.
drop kit, fuel tank
