Old 02-06-2013, 07:15 AM   #1
dirish
dirish's Avatar
where are dash welds? want to take out dash pane.
Going to take out front dash panel, I was told there are two welds plus four
Bolts. I see the bolts, where are the welds, and can a beginner do this?
dirish is offline   Reply With Quote
Old 02-06-2013, 07:33 AM   #2
DaHos
DaHos's Avatar
Re: where are dash welds? want to take out dash pane.
There is more than 2 welds to remove...........more like 20 !
There are spot welds the entire length of the front windshield frame and a couple in the inner corners that need to be drilled out then separated, can be done but time consuming...... other wise remove the bolts and cut the dash along the dash pad seam (oval slots).
1967 C10 SWB
Owner - Rustbelt Restorations
DaHos is offline   Reply With Quote
Old 02-06-2013, 10:06 PM   #3
no_rice
is that what the guys that have used an old dash for decoration done? just cut...?
no_rice is offline   Reply With Quote
Old 02-06-2013, 10:19 PM   #4
TBONE1964
Cluster King
TBONE1964's Avatar
Use a spot weld cutter instead of drilling a hole through both panels. If you are replacing the dash with one from another truck, then the holes at the spot welds should match up. It is a much cleaner job doing it this way.
TBONE1964 is offline   Reply With Quote
Old 11-21-2017, 04:11 PM   #5
Bigtone77
Has anyone done a swap to rhd
Bigtone77 is offline   Reply With Quote
dash, how to, panel, remove
