Old 02-11-2013, 10:19 PM   #1
SnowNeck
SnowNeck's Avatar
lift Kit ideas/options/suggestions
I have a 1985 GMC high sierra step side.(short bed) right now im running 33/12.5/15 on stock set up. no rubbing at all no matter what. the high sierras came with a factory 2 inch lift back in the day. but my leafs a really worn out and i thought why not just get a 4 inch full suspension lift off rough country seems like a good idea at least and real cheap like $450 i believe. anyone ever ran rough country? im not looking for anything over a 6 for right now. its my daily driver during the week but hits the trails an mud holes on the weekend.
1985 High Sierra step side 4x4
SnowNeck is offline   Reply With Quote
Old 02-12-2013, 12:01 AM   #2
Zoomad75
K5Camper
Zoomad75's Avatar
Re: lift Kit ideas/options/suggestions
I've been running 4" rough country springs in the front of my K5 for a few years now. I didn't use the blocks with the kit since I did a shackle flip on the rear springs. The front springs are pretty stiff, but for the price I don't mind. Since the kit had the shocks and raised steering arm it was worth the price. There are better springs out there, but if the budget is tight it will do the job.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 02-12-2013, 08:34 PM   #3
SnowNeck
SnowNeck's Avatar
alright thanks, and yeah i mean its pretty rough now, all leafs are pretty much flat. i have a picture of the truck on my profile. i mean it sits nicely i just need new leafs there shot.
Old 02-15-2013, 12:47 AM   #4
Zoomad75
K5Camper
Zoomad75's Avatar
Leaf spring 4x4's aren't what you can consider "plush" riding to start with. I actually don't mind the high spring rate on my rough country springs. Road feel is firm on pavement but since it's not my DD it's not a big deal to me. Off road, I will usually dump my tire pressure down to 15psi and let the tires soak up the last bit of roughness. Combined with my rear shackle flip mine is pretty soft off road.
Rob Z.
Old 02-16-2013, 12:55 AM   #5
SnowNeck
SnowNeck's Avatar
yeah I wouldn't be doing anything with the leafs or look at lifts if they wernt flat in the front and back. But over all your happy with Rough Country?
Old 02-16-2013, 01:10 AM   #6
Zoomad75
K5Camper
Zoomad75's Avatar
Happy enough not to worry about changing out the springs for anything else. If my K5 was no holds barred billed and money wasn't an issue I'd have some Alcan springs under it. Money is an issue and I'd rather save it up for my 5.3 LS swap than get another set of springs when these do the job.
Rob Z.
Old 02-17-2013, 08:11 PM   #7
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
4" lift should be fine for your needs. I have had a couple of skyjacker lift kits on my trucks and really liked them. Little more money but still not bad. Sounds like your leafs have seen some way better days haha!
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 02-21-2013, 11:07 PM   #8
SnowNeck
SnowNeck's Avatar
Yeah there pretty worn out hahah. its a rough ride. haha heres a picture, i have 33/12.5/15 tires on it
chevy, gmc, highsierra, lifted, liftkit
