Old 02-16-2013, 05:09 PM   #1
toddnshelly
Need 68-72 Aluminum radiator
needs to have a transmission cooler for a 2WD V8 motor
Can anyone tell me what radiator will work, not sure what size to get.
Any websites or part numbers from places like Summit, etc would be a big help in finding a radiator that will work for my 70 rebuild.
toddnshelly is offline   Reply With Quote
Old 02-16-2013, 05:58 PM   #2
Lee H
Lee H's Avatar
Re: Need 68-72 Aluminum radiator
Welcome the the board, wow three year member and one post. Anyway, not enough info to make a good recommendation.
Not sure what your plans are for engine size or power goals but if you have a stock to street/strip build then a $200 four core radiator from your local auto parts store will be more than adequate. Now if you plan on pushing a billion ponies or need to see that shiny aluminum radiator under the hood that's different story.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 02-16-2013, 06:08 PM   #3
Pro Performance
Pro Performance's Avatar
We carry the champion radiators which are an affordable aluminum radiator. They come in 2,3 & 4 row configurations, with an integrated trans cooler. Like mentioned above, is will depend on the engine and HP, to choose which is best for you. Typically a 3-row fits the bill most cases, but again, it all depends.
http://www.azproperformance.com/Cham...369-MC369.html
Pro Performance is offline   Reply With Quote
Old 02-16-2013, 06:58 PM   #4
toddnshelly
Thank you both for your help on this.... yes three year member and only one post :-) ... I joined here before I started my rebuild so I could use these posts and learn what I could before I started.... these forums are a great place to find answers about things other people have had issues with so I can avoid running into the same issues
Old 02-16-2013, 09:15 PM   #5
70cst
70cst's Avatar
Hey toddnshelly ...
to the forums and from Ohio
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 02-16-2013, 10:21 PM   #6
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
I have an aluminum "ebay special" 2 row radiator in my '72 GMC. Been in there for 6 years with a pretty snotty 355 in it. No problems to date.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 02-16-2013, 10:36 PM   #7
buckskins4ever
buckskins4ever's Avatar
If you want to really get a nice radiator, go with a Aluminum 2row Triple pass. You can always go with one without trans cooler build into it and get a race radiator, extend your trans lines via flex under the core support and mount a heavy duty trans cooler on the front of you radiator. Not the cheapest, but I am pushing 430HP Vortec 350 to the wheels, running 700r4, with full posi Eaton 12 bolt diff.....never see above 185 on the temp gauge. Save yourself power drain and install a electric fan from a 98 Lincoln Mark 8.
buckskins4ever is offline   Reply With Quote
Old 02-16-2013, 10:46 PM   #8
KyFarm
KyFarm's Avatar
I have a 4-row radiator from Pro Performance and it is cooling my 402 wonderfully. I bought it from him with two electric fans. I have one coming on with ignition and the other is switched in the cab.
The radiator works so well I have not needed yet to turn on the second fan. Temp stays right on 190
KyFarm's Build/Need help thread
1969 K-10, Short Step, (383HT/4L70E soon)-NP205
KyFarm is offline   Reply With Quote
Old 02-16-2013, 11:28 PM   #9
LSUMurse
LSUMurse's Avatar
I recently got one from Autozone. The core is aluminum and the tanks are plastic. I'm not sure if this is the route you are going for, but it's an option.
4 core, trans cooler built in, $185.
I don't know what temp it keeps my 307, I have idiot lights, but they don't come on.
Part Number is A369.
It's not that I am apathetic, I just don't care.
If your life is a joke, it appears death will be your punchline.
LSUMurse is offline   Reply With Quote
Old 02-17-2013, 12:02 AM   #10
ItsRandy
ItsRandy's Avatar
I have an Entropy radiator with two 16" electric fans. It's only a two row core but it has 1.25" tubes. Kinda' pricey though. 14" fans in the picture. The 16" fans were an upgrade.
ItsRandy is offline   Reply With Quote
Old 10-27-2015, 10:25 AM   #11
DaHos
DaHos's Avatar
Travis, can you please confirm which saddles/hold downs are used for the 2, 3 and 4 core Champion radiators?
thx, D'
1967 C10 SWB
Owner - Rustbelt Restorations
DaHos is offline   Reply With Quote
Old 10-27-2015, 12:27 PM   #12
Pro Performance
I have found that they all use the 4-row mounts, but confirming just to make sure that is still the case.
70 chevy, radiator
