Old 03-27-2002, 06:04 PM   #1
Lumpy
2 tons of fun
Lumpy's Avatar
Post Where to find P/S pulley?
Hello,
I have a 67 pickup with a 350 in it. The power steering pulley is bent and I would like to replace it. I don't think it is the right one anyways because the pulley on the crank and the pulley on the p/s pump are not lined up right. They are off by maybe 1/2 inch or so. Is there any place I can order one? It bolts to the harmonic balancer using 3 allen bolts. There is also a alternator pulley on the inside that is lined up perfectly. The p/s pulley is the outside one. Any help is appreciated. Lumpy
67 Chevy,Short/Fleet,350,Saginaw 4-Speed,Lowered 4x2,small window,P/S,Edelbrock Intake/Carb,HEI,Gear Drive,Crane Cams 274h
Three Rivers, Ca
Pic at: <A HREF="http://community.webshots.com/album/29068416etoBoEninp
" TARGET=_blank>http://community.webshots.com/album/29068416etoBoEninp
</A>
67 Chevy,Short/Fleet,350,Saginaw 4-Speed,Lowered 4x2,small window,P/S,Edelbrock Intake/Carb,HEI,Gear Drive,Crane Cam 274H
Three Rivers, Ca
Pics at: http://www.cardomain.com/id/lumpy454
Lumpy is offline   Reply With Quote
Old 03-27-2002, 08:11 PM   #2
Fast68Chevy
Fast68Chevy's Avatar
Post
well sine its a 67 with an incorrect engine in it, then its probably way kimmy rigged up, does the engien have a long or short water pump ? i have both the flat pulley that sits directly on the balancer in 67-72 and also i have the 1 /3/4" wide dished pulley thats the add-on for p/s belt in 67-72
what numbers are stamped onto your pullies ?
and do you have corr4ect p/s pump brackets ? the ones that extend back to the engine mount ?
-71/C-10(thx teeitup and crews!)350 4+4/CH465(thx 71Chev, GMCPaul, and CPNE)longfleet bed(thnx meathead95)!still building it-
-'84 Z28(Z28) 1G1AP87GXEL100000 with H.O. 305/4bbl/190net/hp(L69) 3.73 rear(GT4/YC4) 700R4(MD8-MXO) & other goodies
-79 G20 pass van, 350/th350/10bolt,
paint is overrated
Randy- Lincoln, IL
r68c30@hotmail.com
© RSS Enterprises 2000
Fast68Chevy is offline   Reply With Quote
Old 03-27-2002, 08:28 PM   #3
Lumpy
2 tons of fun
Lumpy's Avatar
Post
Fast. It is a short water pump. The P/S bracket is like you said and goes back and mounts to the motor mount. I have a single groove pulley for the water pump that is flat and the i have that dished one like you said for the p/s. But the dished one does not line up good with the P/S pulley. The crank p/s pulley is about 1/2 off closer to the radiator then the actual P/S pulley. Can I just order a double groove crank pulley? Thanks.... Lumpy
Three Rivers, Ca
Old 03-27-2002, 08:29 PM   #4
Lumpy
2 tons of fun
Lumpy's Avatar
Post
Oh yea.. Both crank pulleys measure approximately 6.75 inchesin diameter. I cant see a number on the pulley. Thanks
Three Rivers, Ca
Old 03-27-2002, 08:58 PM   #5
gregsplace
gregsplace's Avatar
Post
p/s pump could have wrong pulley on it, should be flat pulley, not the dished back one, if I remember right.
67 3/4 4x4 402,a/t,flat bed
98 GMC Sierra swb daily driver
87 burb parting out.
68 1/2 chevy, 350/350, 71 gmc frame, kid's beater
69 1ton 396-4sp, dump
69 swb stepside 396/400th current frameup
67 swb 454/400th rebuilding now, oldest boy just rolled it
99,HD, Road King Classic
Colwich Ks
gregsplace is offline   Reply With Quote
Old 03-27-2002, 09:08 PM   #6
Lumpy
2 tons of fun
Lumpy's Avatar
Post
Greg,
The P/S pump pulley does have a bit of a dish to it. If it were flat it appears it would line up perfectly. But since my crank p/s pulley is bent it looks like I may be able to use an aftermarket aluminum double groove crank pulley it it would line up.
Three Rivers, Ca
