Old 02-28-2013, 10:00 PM   #1
turner16
Box Removal
Can someone tell me how to get the box bolts out with the nuts spinning? This is on my 2001 long box. What a crappy design. I assume GM welded the nuts in and now the welds have let go. I could just cut the bolts but then I couldn't reuse the nuts as they would be filled and still spining
turner16 is offline   Reply With Quote
Old 03-01-2013, 09:38 AM   #2
truckdude239
truckdude239's Avatar
Re: Box Removal
might have to use a hole saw and cut a hole in the floor above the nut and use a socket to hold them
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 03-01-2013, 01:33 PM   #3
gmclowsierra
Re: Box Removal
How many are spinning? If its only one or two just cut the heads off and leave those holes empty. There should be like 8 bolts holding it to the frame.
gmclowsierra is offline   Reply With Quote
Old 03-02-2013, 02:14 AM   #4
grumpyolddog
Cool Re: Box Removal
;You need to cut a window in the side of the u channel by the bolt to get ahold on the nut,you can install a j clip nut on though the hole to install the box
grumpyolddog is offline   Reply With Quote
