Old 03-13-2013, 10:09 AM   #1
PortalAxls
PortalAxls's Avatar
V6 VS V8 radiators
Question for you guys. Are there any differences between the V6 and V8 radiators? I don't know if the previous owner had swapped radiators or not. When I called the local shop to order one they had me measure the distance between the retainers. I got 26, and I see the radiators listed for our trucks are 28.
I just noticed yesterday while tinkering that there are holes for the retainers 2" from where the retainers were originallly mounted. Should I just move the retainers over for the 28" radiator?
Also, the pads I bought from LMC seem to be a different size than what came on my truck.
here is a link to the one I bought from the radiator shop before seeing the other mounting points http://www.summitracing.com/parts/pli-438162
And the one listed for our trucks http://www.summitracing.com/parts/pl...rview/make/gmc
67 GMC K2500. 305D V6, 4 spd, rotted wood bed, and lots of rust!!
WTB: Eaton HO 4:10 or 4:11 tapered beaing gearset, or complete 3rd of either style bearing in the 4:10 ratio
PortalAxls is offline   Reply With Quote
Old 03-13-2013, 10:27 AM   #2
PortalAxls
PortalAxls's Avatar
Re: V6 VS V8 radiators
Also, here are some pictures of my fan shroud. Not sure if it is the correct one, it came with the truck sitting in the bed.
Old 03-13-2013, 10:33 AM   #3
PortalAxls
PortalAxls's Avatar
Numbers I found on the fan shroud.
Old 03-13-2013, 11:12 PM   #4
Captainfab
60-66 Nut
Those radiators on Summit are spendy. Have you checked your local auto parts supplier?
Old 03-14-2013, 08:18 AM   #5
PortalAxls
PortalAxls's Avatar
I am just curious if the GMC V6's used the 26" or 28" radiators.
I can get the same models through my local radiator shop for 100$ cheaper, in fact after getting them the retainer width, they ordered me the one in the first link. I just wanted to make sure the GMC V6 didnt have a specific radiator before I return the one I currently own which is in the first link, and buy the 28" truck radiator in the second link. I guess I will have a custom shroud made if need be. Of course I don't even know if the shroud that came with the truck is the right one.
Thanks in advance for any help.
Old 03-15-2013, 10:00 PM   #6
pritch
pritch's Avatar
Another thing you'll need to do if your putting in a different width radiator is move the lower mount, too-mount's the wrong word. The rubber and tin deal that the radiator sits in. There is a wider or narrower option down there, too. These are riveted in, so to move it, you need to grind off the rivet, and then use-at least I used-a small, like, 1/4 or 5/16th carriage bolt to hold it back on.
'68 Panel
Project Boogie Chillin'
'68 C-10
Ol' Green
pritch is offline   Reply With Quote
Old 03-15-2013, 10:33 PM   #7
PortalAxls
PortalAxls's Avatar
It looks like the PO already moved it. It has a small carriage bolt holding it on. I was looking at it during my lunch break. Luckily my local rad shop is run by a bunch of good people. I am exchanging the 3 row 26" I currently have for either a 3 or 4 core 28". I am debating between the 3 or 4 core right now.
Thanks for the help guys!
Old 03-16-2013, 10:15 PM   #8
storm9c1
*** That's interesting ***
storm9c1's Avatar
Which upper and lower mounts do you have? If you have the 3-core mounts, then you had better get a 3-core. Otherwise you will have to order at least the uppers. And pads. I think the lowers can be coerced to work with a 4-core IIRC.
Tom
Chevy by day...
1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E
2011 Chevy Caprice PPV 9C3 6.0L
1995 Chevy Caprice 9C1
1994 Chevy Caprice 9C1 #3
1995 Chevy Caprice Wagon #2
1995 Chevy Impala SS
Mopar by night...
1969 Dodge Charger
1972 Chrysler Newport 2dr Hardtop (27K miles)
Plus others...
storm9c1 is offline   Reply With Quote
1967, 305d, 305e, radiator
