![]() Join Date: May 2005
07 maintenance lights
My 07 has the tpms light and message for service as well as the airbag light and message. How do I get these to go away?
Re: 07 maintenance lights
Find out the problem that set the lights off and repair them. With it being an 07 the batteries in the sensors could have finally died, a sensor could just be bad, low tire pressure, Could need to have sensors relearned if it wasn't done when one was replaced, receiver could be bad... Air bag could be impact sensors, seat belt pretensioners, wiring, clock spring, module... point is you need it diagnosed and codes read to figure out where the problems are and go from there to get them repaired properly.
