Old 03-21-2013, 01:23 AM   #1
bigwheel15
bigwheel15's Avatar
Replace fuse block
Okay so im wondering how complex it would be to swap the fuse block located under the dash with another one? Now to explain, for whatever reason in my trucks previous time before I owned it apparently there was an issue with the radio wiring shorting and causing the area around the radio fuse on the block to melt. I have went though the wiring and checked everything out and all has been taken care of except for the fuse block.
What all would be involved in taking a block from a donor truck and swapping it out?
bigwheel15 is offline   Reply With Quote
Old 03-21-2013, 11:21 PM   #2
bigwheel15
bigwheel15's Avatar
Re: Replace fuse block
Any ideas?
Old 03-24-2013, 03:19 AM   #3
bigwheel15
bigwheel15's Avatar
Bump again
Old 03-24-2013, 05:19 AM   #4
andrewmp6
With out rewiring the whole truck i don't see it being moved more then a inch or two.
andrewmp6 is offline   Reply With Quote
Old 03-24-2013, 10:58 AM   #5
JellyBeanDriver
I considered this on the 86' ranch truck we have. For only the plastic block to be swapped, you'd have to pull the pins from the rear of the block by depressing tabs on each terminal from the front side of the block.
Similar to you, I have a burned hole where the parking light fuse was (trailer wiring short). It was patched around using an inline fuse holder outside of the original fuse block.
I did replace some other terminals one at a time (collateral damage), but these were all on the load side of the fuse block - single terminals. The power side of the fuses, a lot of them are bussed together. You would have to simultaneously depress the tabs on all the terminals to get the bussed ones out. Might be able to walk them out, not sure.
JellyBeanDriver is offline   Reply With Quote
Old 03-24-2013, 11:30 AM   #6
48cj2a
48cj2a's Avatar
I did this last summer on my CUCV Blazer.
Its not hard but very time consuming and you need a lot of patience.
You need to extract the packard terminals one at a time and then correctly insert them in the new block.
Its also much easier to pull the whole harness out of the dash and do this on the table or work bench.
03 Suburban Z71 Z71
98 GMC Yukon SLT 4x4 Yukon
86 M1009 CUCV Project Milverado
48 Willys CJ2A 48CJ2A
48cj2a is offline   Reply With Quote
