Old 03-23-2013, 09:34 PM   #1
LynnJr
1974 Stepside Fleetside Fuel Tank Problem
I am putting together a 1974 truck that was originally a fleetside shortbed.I had the fuel tank powder coated black and the straps powder coated white.
I had a change of heart and put a stepside bed on and now have no way of filling it up as the gas tank filler is on the wrong side for a stepside.
I don't want to replace the tank is there any way of fixing this?
LynnJr is offline   Reply With Quote
Old 03-23-2013, 11:02 PM   #2
RAYZDUP85
Re: 1974 Stepside Fleetside Fuel Tank Problem
should be able to unbolt your tank brackets and swap them to the side where your filler is. may have to change filler hose
RAYZDUPNCREWZN 1985 CCSB 4X4
RAYZDUP85 is offline   Reply With Quote
Old 03-24-2013, 07:31 AM   #3
88Jimmy4x4
88Jimmy4x4's Avatar
what year stepside bed is this?......you saing your tank is on pass side and filler door is on driver side?
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 03-24-2013, 09:59 AM   #4
LynnJr
The truck was originally a fleetside and the tank is on the drivers side.
I put a stepside bed on it and the fill neck is now on the passenger side.
I will try switching the bracket.
Old 03-24-2013, 10:12 AM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
The front brackets are side specific. There are factory welded on nuts that only align on the proper side of the frame. You can swap them to the other side but you'll have to use bolts and nuts because the factory welded nuts won't align with the holes on the other side of the frame.
Old 03-24-2013, 10:13 AM   #6
88Jimmy4x4
88Jimmy4x4's Avatar
filler necks are different from stepside to fleetside
1991 GMC Jimmy 4x4
Old 03-24-2013, 10:31 AM   #7
LynnJr
Thanks guys its 7;30 AM and I'm headed to the pick ur part to see what they have.
