03-30-2013, 02:40 AM | #1 |
Anyone used a Drop down battery box ?
Im thinking about using on of these.Have not found any pics of this style battery box on the 64-66 C10. So I'm looking for detailed mounting pics.
Thanks in advance.
Always a place in my heart for old Chevy trucks: My build thread-project truck dream 65" http://67-72chevytrucks.com/vboard/s...d.php?t=510863 |
03-30-2013, 12:37 PM | #2 |
Re: Anyone used a Drop down battery box ?
Lots of you looking,still waiting for some pics ! Here's a pic for inspiration !
Cheers.
03-30-2013, 06:28 PM | #3 |
I bought one to use from CPP but after about half a minute I realized... unless I was a static... why would I want to relocate my battery to the back of my frame rail. Id have to put it between the cab and the passanger side wheel and with being porterbuilt rear and sectioned front, my body is on the ground. If I ever had a electrical drain or compressor or you name it... left my damn lights on. I now have no way to get at my battery unless I installed a hinge system on my box and then it just gets even more complicated.
Personally after really thinking about it, All my wiring I can safely run of a ditribution block, or off the starter I will. Only thing to my battery direct will be my fast and main/ground. I'll run side post and hide them into the inside of my fender wells. Takes more time... but thats ok. BTW I have a battery box for sale haha.
1966 C10 Shortbox - Full CPP build http://67-72chevytrucks.com/vboard/s...d.php?t=519829 |
03-30-2013, 07:13 PM | #4 |
Got one on mine installed under bed on passenger side. Major pita to jump or charge battery. Works best if a floor jack is under it to lift battery back up. Nice though considering i I can lay down to do all battery work. With all those perks, I would still sell you mine.
03-30-2013, 07:16 PM | #5 |
Chevy Fleetside...member has a drop down behind the cab, you`ll have to do a search.
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
03-31-2013, 12:53 PM | #6 |
I dont have a box yet. I still might put it in the bed with a cover over it.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
03-31-2013, 03:15 PM | #7 |
I remember my '57 had it in the cab under the pass. side floorboard. I wouldnt think it would have worked for layin' frame though. Id'd like to find a driver's side inner fender with a battery box cutout so I could run duals. Come to think of it, the underfloor set up would work for a lifted rig.
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
03-31-2013, 04:52 PM | #8 |
2WD Jimmy
I need all the traction I can get, I have the CPP unit.
Posted via Mobile Device Posted via Mobile Device |
04-07-2013, 02:43 PM | #9 | |
Cheers, Ed
04-07-2013, 02:44 PM | #10 | |
Cheers, Ed
04-07-2013, 02:45 PM | #11 | |
Thanks, Ed.
04-07-2013, 07:52 PM | #12 |
Helped a buddy put one in an out-of-sight box in the trunk of a fuh-fuh--fohohohorgetit. We got some charge/jump start terminals an mounted them just above the bumper in an out of the way place. Works great! He left his key switch and found the car dead later in the week. Putting a charger on it the "new & improved" system.
Thinking of putting one in the passenger rear fender on the frame.
Jeff 96 C3500 Crew Cab Long bed (Waiting on Cool Name) 64 C-10 shortie stepside, "Ole Brownie" C-10 Club My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345 |
11-23-2014, 04:08 PM | #13 | |
Proud owner of a 55.1 AD
Thinking about running the same battery box with my Jimmy. Since you have had the battery box for awhile, any issues? How close is it to the rear tire? Would you do it again? Any other clearance issues? Thank you, Bob |
