Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 GMT400 Chevy & GMC Pickups Message Board > projects and builds 88-98
Old 03-30-2013, 10:45 AM   #1
93redsled
tuck'n 20s
finally got motivated again put my disc brake kit on. I bought the SSBC front and rear disc setup, the rear is an 11in rotor with a single piston caliper, powdercoated black. the fronts are I think 12in rotors with a dual piston caliper.
93redsled is offline   Reply With Quote
Old 03-30-2013, 10:48 AM   #2
93redsled
Re: tuck'n 20s
heres more of the rear
Old 03-30-2013, 03:45 PM   #3
YBNORML
YBNORML's Avatar
Re: tuck'n 20s
Very nice! Looks like a pretty straight forward upgrade.
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 03-30-2013, 06:52 PM   #4
93redsled
Re: tuck'n 20s
Yeah it was all bolt on and very simple, ill post some pics of the front soon.
Old 03-31-2013, 07:52 PM   #5
1badgmc
1badgmc's Avatar
Re: tuck'n 20s
Nice. My truck could use that setup.
Old 04-01-2013, 09:47 AM   #6
jb1016
"Oh well, it's a driver."
jb1016's Avatar
Re: tuck'n 20s
That does look easy. Which means it's probably out of my budget, lol
Nice truck too!
Old 04-02-2013, 12:46 AM   #7
cable666guy
cable666guy's Avatar
Re: tuck'n 20s
Sharp looking truck !
cable666guy is offline   Reply With Quote
Old 04-05-2013, 03:25 PM   #8
93redsled
Re: tuck'n 20s
thanks...here's some pics of the fronts! i installed these Boss 335s and realized after installing them the hub sticks out to far and the center caps will not fit. i called Boss and they told me i had to install a spacer but if I do that'll cause the wheel to rub on the fender. any suggestions?
Old 04-05-2013, 03:39 PM   #9
93redsled
Re: tuck'n 20s
I also replaced all the weather stripping, GM still makes all the stripping for our trucks and i saved all the part numbers if anyone needs them.
No more air leaks!!!!
Old 04-06-2013, 02:14 PM   #10
made2drag
made2drag's Avatar
Re: tuck'n 20s
awesome setup...your truck is sweet! what size tires are they?
made2drag is offline   Reply With Quote
Old 04-06-2013, 03:30 PM   #11
93redsled
Re: tuck'n 20s
Thanks bro, I went all out before the wife and kids come...lol. But the front are 255/40r20 and the rear are 275/40r20 on 20x8.5 wheels
Old 04-06-2013, 04:03 PM   #12
dragginmetal
here, just not logged in
dragginmetal's Avatar
Re: tuck'n 20s
On the center cap problem, Could you put a shorter hub cap on. I'm guessing the problem is the heavy duty spindles have longer hub caps. 335s fit my '88 fine, but the person i got them from said they had to run spacers. So it has to be the 88-91 spindles has shorter hub caps. My hub caps are 5/8" long.
dragginmetal is offline   Reply With Quote
Old 04-06-2013, 10:12 PM   #13
lokitruck
Re: tuck'n 20s
I also have 335s on my 92 silverado and have this problem so if and when you figure it out please tell me how to fix it
lokitruck is offline   Reply With Quote
Old 04-07-2013, 03:02 PM   #14
93redsled
Re: tuck'n 20s
You are correct that the heavy duty brake setup is the problem, I didn't realize 88-91 had a different brake setup. I tried with the dust cap off but it still hit on the rotor/hub. From what I looked up the spindles and the rotors are different between 88-91 and 92-98. The rotors have a 1/4in difference and that is about how much the rotor/hub stick out past the wheel. P
Old 04-10-2013, 09:25 PM   #15
OrangeAnimal
OrangeAnimal's Avatar
Re: tuck'n 20s
I'd like to know more about your rear link setup. Where did you get that from and is it on bags or coil springs?
82 Chevy SWB "OrangeAnimal" Lot of Goodies! Sold
93 GMC 1500 "Angry Red" 383 TBI Powered Fun! 300hp/410ft.lbs.
09 Yaris wife's daily.
OrangeAnimal is offline   Reply With Quote
Old 04-10-2013, 09:28 PM   #16
OrangeAnimal
Re: tuck'n 20s
Oh and nothing works quite like flattening the cap down to the point it almost touches the spindle on the inside. Also depending on how much space you need on the rotor you could remove some material from it. I would see how I could shape the bearing cap to make it work.
Old 04-10-2013, 11:19 PM   #17
93redsled
Re: tuck'n 20s
The setup is from ridetech and its on bags. Awesome quality and install was pretty basic. As far as the front center cap goes I have thought about having the rotor hub machined down but I'm not in love with the wheels so I may just change the wheels. I'll post some pics of the rear setup soon.
Old 04-17-2013, 02:22 PM   #18
93redsled
Re: tuck'n 20s
Need some input.... I just read about plastic dip, I researched it the best I could this morning and I'm wanting to know has anyone tried this and on what? How does it hold up on wheels when they get wet or when brake dust gets on the wheel?
Old 04-17-2013, 05:49 PM   #19
nt30
Re: tuck'n 20s
I haven't plasti-dipped my rims yet but have done body parts (bumpers, mirrors) on the missus's FJ. Has held up really well for 2 years so far.
nt30 is offline   Reply With Quote
Old 04-29-2013, 06:21 PM   #20
dhjernigan
dhjernigan's Avatar
Re: tuck'n 20s
I have just installed the same Ridetech 4 link air bar on the rear of my 89 GMC RCSB Stepside truck and CoolRide air bags and shocks on the front and am trying to figure out what wheels to get for the truck, I currently have Eagle Alloy 211's 17 x 8 with 5 inch offset and they don't come close to going inside the fenders. I want either 17, 18, or 20 inch wheels. What is the offset and dimension of the wheels and tires that you have on the rear and front??
David
dhjernigan is offline   Reply With Quote
Old 05-01-2013, 09:21 PM   #21
93redsled
Re: tuck'n 20s
I'm running 20x8.5 boss 335s w 5.671in backspace With 255/40/20 on the frt and 275/40/20 on the rears. They tuck frt and rear without having to cut or roll the inner lip but you'll want to for added room. IMO the frt tire to tall I may go a smaller tire.
Old 05-01-2013, 09:27 PM   #22
Vega_67C10
Vega_67C10's Avatar
Re: tuck'n 20s
I like. Looks great.
I Saw Elvis at 1000 Feet - John Force
Vega_67C10 is offline   Reply With Quote
Old 05-01-2013, 10:08 PM   #23
93redsled
Re: tuck'n 20s
Thanks Vega, I just hope it turns out as cool as yours!
