04-02-2013, 12:00 AM | #1 |
Aftermarket Headers Vs. Stock Manifolds
What do you guys think? When I bought my truck she had Hooker headers with a big nasty dent in the driver's side header. They seem to be more trouble than they're worth. They're hot and they're in the way of eveything.
Since I'm replacing them I'm wondering if I should get similar headers and wrap them, get shorter headers, or just go with the stock manifolds from a pick and pull. Thoughts?
1982 GMC C1500 4x4 w/ 305 and sm465. 2002 Kawasaki Ninja 250. 2007 Dodge Nitro. |
04-02-2013, 12:10 AM | #2 | |
Re: Aftermarket Headers Vs. Stock Manifolds
Michael Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9 |
04-02-2013, 12:13 AM | #3 |
My engine isn't stock either. Intake, carb, cam, headers, and starter are all aftermarket.
04-02-2013, 07:24 AM | #4 |
Go Hard or Go Home!
headers are good for performance not to mention the sound. they come with issues tho, blown header gaskets, header bolts coming loose. these issues are rare with stock manifolds. i'm still running hedman headers with 40 series flow masters. like everyone else running headers, i just deal with the issues.
75 short wide 350, some mods, scare the piss outta ya quick. 2008 Dodge crew cab. YEAH, it's got a hemi, your ass is going to jail quick. Some day's, it's just not worth chewing through the restraints................................ |
04-02-2013, 08:57 AM | #5 |
Before I did an ls swap, I was running some cheapo flow tech headers. I rarely had a issue with them. Maybe once every couple years I would need new gaskets. But I never once had an issue with bolts coming loose. A tip for that is put a little copper silicon on the threads before installing the bolts. My starter was a piece of cake to remove as was oil filter. There were a couple plugs that posed a challenge to change.
Posted via Mobile Device |
04-02-2013, 11:51 AM | #6 |
78K & 79C Jimmys
I clean out stock manifolds
dosn't make it any quieter lol with flowmaster 40s, it sounds like more then stock 305-2B that it is
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
04-02-2013, 12:50 PM | #7 |
You could always try the ram horn manifolds like the ones at speedway motors. They look good and have plenty of clearance for plugs.
Jeramy '84 GMC project truck '85 Chevy 4X4 SOLD '07 Chevy Trailblazer SS 5th Annual SHPHC Car/Truck Show Pics http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT |
04-02-2013, 12:57 PM | #8 |
Not to mention they flow great as well.
04-02-2013, 01:35 PM | #9 |
My current truck has headers on it (big block) they are a royal pain in the ...
It's just a stock truck with a big block, I'm changing it back to manifolds next week with a single 3'' pipe and a magnaflow muffler. More than enough for what I use the truck for. |
04-02-2013, 02:10 PM | #10 |
What makes it such a pain? Also what brand did you try?
04-02-2013, 02:45 PM | #11 |
The headers were on the truck when I bought it, so I have no idea what brand they are...........ah, the pain.....how about leaking gaskets at the head and the collector about once year it seems, spark lug access burned wires occasionally, because the shields got tossed when the headers were put on. MY OPINION on headers for a stock truck....not needed....other mods can be made without first tearing the whole exhaust apart front to back.
AND let's not forget the usual starter overheat, big block, summertime etc. |
04-02-2013, 02:59 PM | #12 |
just to answer in short form Headers Suck
1946 car hauler 1948 surburban 1937 chevy sedan 1940 olds sedan (project) 1967 ss396 chevelle 1999 dually crewcab(24000 miles) |
04-02-2013, 03:03 PM | #13 |
Im a firm believer that if they are a quality header and installed right ie tightening every couple hundred miles for a couple thousand and proper heat shielding installed they should be fine. I was told to watch for a good thick mounting plate surface to prevent warping makes a world of difference with a bbc.
04-02-2013, 03:18 PM | #14 |
Using lock washers keeps the bolts from loosening.
Number 5 and 4 or 6? Cylinder plugs can be a little tricky. A gasket company called REMFLEX makes great gaskets that will seal headers that are more warped than a politician. A good header will increase torque over any manifold because they use a collector which scavenges the exhaust out of a cylinder basicly. Basic header works. A longer tube produces more low end and shorties produce top end but are good for clearances and other uses Manifolds are sturdy and low maintenance but they can crack and they also don't flow to good. Exhaust routing is easy and they don't make it hard to get to plugs and such I prefer headers but I use my truck differently than most Posted via Mobile Device
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
04-02-2013, 04:04 PM | #15 |
for me the benefits of headers far out weigh the cons of them!
"DON'T TOUCH THE TRIM!!"-Early Kyler |
04-02-2013, 04:15 PM | #16 |
my stock manifolds leak 454 , im afraid to tighten them up , something is goin to break ......Im thinking headers and new dual exhaust will be better
88 3+3 454 400 205 410 drw to srw still in pieces 90 3+3 350 400 205 410 srw 84 1/2 ton lb 6.2 4x4 parts truck |
04-02-2013, 05:28 PM | #17 | |
Watch out for your cornhole !
That said, I put a pair of new cast iron manifolds in my big block truck recently. Dorman brand. Good fitment and substantially beefed up in several areas compared to the original manifolds. Rockauto had the best bottom line price including delivery compared to everyone else. Posted via Mobile Device |
04-02-2013, 05:37 PM | #18 |
Headman makes a nice mid length header for these trucks. My old 79' I got rid of had a set of hookers on it . I think I replaced a header collector gasket once in I don't know how many years they were on that thing.
04-02-2013, 06:15 PM | #19 | |
04-02-2013, 06:38 PM | #20 |
Unless you are building a vehicle strictly to race, I don't get the benefit of headers. I am biased - my neighbor has headers on his old Ford 250 diesel and he wakes me up in the morning frequently when he starts it up.
04-02-2013, 06:45 PM | #21 |
headers look better flow better sound better lighter weight, whats there not to like?
77 c10 (went from a inline 6 to 350) (converted to 3 speed in the floor) 350: mild cam, holley 600cfm 4bbl, summit stage 1 intake, accel billet distributer, flowtech headers, 2 1/4" exhaust with glasspacks, powermaster 160a alternator. |
04-02-2013, 06:48 PM | #22 |
torque and fuel economy, thats the benefit!
04-02-2013, 09:47 PM | #23 |
78K & 79C Jimmys
i was told to tighten the manifolds or headers middle to outside
and torque more for the 4 inside,then 4 out
04-03-2013, 06:01 AM | #24 |
04-03-2013, 08:06 AM | #25 |
There's plenty of opposing viewpoints on this subject
Posted via Mobile Device[/QUOTE] I'll say..Every thread about headers is the same..Drives me crazy. I read every one and keep changing my mind every time. It seems to be pretty much 50/50 for or against. |
