04-12-2013, 01:50 PM | #1 |
68 2wd to 4wd
I have a 68 CST two wheel drive truck with long bed, stock 396, turbo 400, factory air, etc. and I am wondering if it is worth converting it to four wheel drive.
04-12-2013, 02:02 PM | #2 |
Rusty Nuts
Re: 68 2wd to 4wd
Its only worth it, if that is something that you really want.
(Clever Missouri) Southwest Larry Mr Chevrolet My Build, The Marathon Truck http://67-72chevytrucks.com/vboard/s...d.php?t=604414 |
04-12-2013, 02:09 PM | #3 |
Re: 68 2wd to 4wd
You'll get quite a bit of advice that it is easier to buy a 4wd long bed frame and swap the body over. Dieselwrencher used a 2wd frame and took parts off a 4wd frame to convert his. http://67-72chevytrucks.com/vboard/s...d.php?t=310493
04-12-2013, 02:19 PM | #4 |
Re: 68 2wd to 4wd
I think my truck is rare because of the cst, 396, turbo 400 and factory air. I own a late model chevy diesel 4x4 so I do not need one. Would I make the 68 less valuable? I found a 68 3/4 ton 4x4 I can buy cheap and use just the chassis. I would rather it be a 1/2 ton I think but?
04-12-2013, 02:26 PM | #5 |
Re: 68 2wd to 4wd
yeah you would probably take away some value. and i would go 1/2ton if it were 4wd your gas i bad neough with the 396 plus the 4wd will be worse and then with 3/4ton you really wont be able to drive it
04-12-2013, 02:44 PM | #6 | |
Proprietor of Dale's Corner
Re: 68 2wd to 4wd
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
04-12-2013, 02:57 PM | #7 |
Re: 68 2wd to 4wd
what about in town?? haha probably 10 or 9... same for my 68 4wd though but the 3/4 ton in the mix you probably get 5 in city 10 on freeway? LOL and with gas at basically 4 dollars a gallon and a 22 gallon tank...you wont have many full tanks.. unless of course your last name is leno.
04-12-2013, 11:32 PM | #8 |
Re: 68 2wd to 4wd
i did with mine, but only because i need 4x4 where i live. i say probably not on yours unless you need it. plus sounds like yours is heavily loaded. Now i want to see a pic.
04-13-2013, 12:59 AM | #9 |
Re: 68 2wd to 4wd
Here is the truck pics I hope they show up because I am learning how to use this process.
