Old 04-16-2013, 10:21 PM   #1
slam59
Need water pump for 99 tahoe
My 99 Tahoe needs a water pump and I was looking at prices online and it says it is highly reccomended to replace the fan clutch at same time? I never heard this, is this a must and why?
1974 C10 swb 350
1977 3/4 ton Silverado 454
1999 2 door 2wd Tahoe
slam59 is offline   Reply With Quote
Old 04-18-2013, 06:04 PM   #2
Benny-
Re: Need water pump for 99 tahoe
I replaced the water pump on my '00 Silverado. I've never read or heard anything like this. Why fix it if it works properly? I would suggest, however, replacing the thermostat while you have everything apart. Mine went out about 10K after I replaced the water pump.
Benny- is offline   Reply With Quote
Old 04-18-2013, 06:14 PM   #3
95 S_Trucker
95 S_Trucker's Avatar
On a 99 Tahoe, the thermostat is not housed in the water pump, it's on the intake manifold. Its up to you if you want to replace it. I wouldn't replace the fan clutch unless there is something wrong with it.
95 S_Trucker is offline   Reply With Quote
