![]() Join Date: Jan 2008
Calling Captain Fab - which is it?
I want to get the pieces together to install a power brake system in my '60. I read the threads on the topic and want to order your kit. You wrote in one reply you could use a pic of the slave cylinder to ensure one gets the right clutch master cylinder when placing an order.
Well, here's mine. I thought this might be used by others when identifying what their truck has - maybe you could reply here and post a pic of the 'other' slave cylinder you aluded to. In any event, if you'd please PM me with what kit is available for my '60 I'm ready to order. Thanks, Brad |
Re: Calling Captain Fab - which is it?
send him a pm
ron |
Yep, did that.
60-66 Nut
![]() ![]() Join Date: Mar 2007
I replied to your PM Brad
I have a 1962 c-10. I'd like to order the brake booster adaptor, powder coated, no clutch. Also the power steering adaptors. I guess there is an inner and an outer bracket? Also the rear end bracket to bolt on a later rear end to my stock trailing arm suspension. Thanks
Never Ending Projects
Moved this to the Vendor Marketplace as this is the correct area for these questions.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
#7 | |
60-66 Nut
I will send you a PM with ordering and payment info.
Mike,Thanks for moving my thread to the right page for me. I'm new to this site and could use a little help. I loved your parting comment! Some day I hope to be as smart as you.
