Old 03-24-2002, 10:59 PM   #1
Blue_71
Bloo
Blue_71's Avatar
Post help!! motor problem
me and my best freind have been working on the 4x4 all day trying to get it to start. when we had the engine on some blocks, it turned fine. when we had it in the air it turned fine. when we had it almost on the transmission it turned fine. now that its all the way on and bolted to the transmission it wont budge any at all. whats causing it to be in a bind like this? it wouldnt freely slide back onto the clutch pilot shaft either, we had to pull it back to the transmission using bolts. we had to replace the pilot shaft bearing, is there different size bearings? we treid to turn the flywheel with a screwdriver on the flywheel and it almost bent the screwdriver (it was one of the really big ones) so whats causing it to not turn now that its on the transmission?
thanks for any help
J.B.
1971 chevy 3/4 ton 4x4, 355 SB, SM465 4 speed manual, NP205 t-case, eaton 10 bolt corp rear with 4:10 gears
(edited this ---> 1921 chevy 3/4 ton )
[This message has been edited by Blue_71 (edited March 25, 2002).]
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 03-24-2002, 11:39 PM   #2
CoryM
Post
Sorry man, But i have to ask if the tranny is in Neutral? Did you use a clutch alighment tool? Did you try to fit the new input shaft bushing over the input shaft before installing? Does the clutch feel right when you push it in? If you can't figure out whats up you are going to have to unbolt the tranny agian and find out. Something is not right there.
Let us know.
CoryM
1970 heavy duty C-10 fleetside sport truck. Vancouver B.C. Canada
http://www.geocities.com/chevroletc1070
"Take up our quarrel with the foe:
To you from failing hands we throw
The torch; be yours to hold it high."
Lieutenant Colonel John McCrae, Canadian Army
CoryM is offline   Reply With Quote
Old 03-24-2002, 11:58 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post
Could the tranny be locked up? How bout the Transfer case?
'69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it.
Need to pick up the one ton Longhorn with a PONTIAC 350/350soon.
Thanks every one!
Check out The Longhorn Webite.
If you need a pic posted, E-mail me at longhornmail@yahoo.com
Andy, in Columbus Ohio
[This message has been edited by longhornmail (edited March 24, 2002).]
Old 03-25-2002, 04:49 PM   #4
Blue_71
Bloo
Blue_71's Avatar
Post
tranny is in neutral, i jacked up the rear and put the t-case in 2-hi and that turned fine, so i know its not in the t-case. the only thing i can figure out is the tranny must be locked up. we used a clutch alignment tool, but the guy who put the bearing in for me didnt try to fit it on the pilot shaft because he thought they were all the same.i guess tomarow i'll go get a turbo 350 from another freind of mine, he said i could use it untill i figured out whats up with the 4 speed.if its just the tranny locked like im thinking the TH350 should work fine if its ok, right?
J.B.
1989 Chevy K2500
Old 03-25-2002, 04:52 PM   #5
71GMC_3/4T
Weapons Of Construction
71GMC_3/4T's Avatar
Post
Can you try disengaging the clutch? That would tell you if it's the tranny locked in two gears or something else.
1971 GMC 2500, 402/TH400 4.10 Daily Driver
Lafayette, CO
71GMC_3/4T is offline   Reply With Quote
Old 03-25-2002, 06:08 PM   #6
Gordo
Red face
Before something bends or breaks (hopefully not to late) seperate the trans from engine and look for the cause. The engine and trans should bolt up easily without having to pull it together with the bolts if everything is lined up correctly.
1971 C10 swb stepside 350/700R4/3.73posi
Killingworth, Connecticut
1971 C10 swb stepside 350/700R4/3.73posi (retired as of 4/22/03)
1998 S10 short bed
2002 S10 Blazer
1942 Oldsmobile
1958 Massey Harris Pony
1951 Wife
May those who love us, love us, any of those who do not love us, may God turn their hearts.
And if God is unable to turn their hearts, may he turn their ankles so we may know them by their limping.
A man who works with his hands is a laborer; a man who works with his hands and his brain is a craftsman; but a man who works with his hands and his brain and his heart is an artist.
Gordo is offline   Reply With Quote
Old 03-25-2002, 08:09 PM   #7
71402BB
now thats a true COON DOG
Post
yep Gordo is 100% correct! for some reason the engine seems to like to slide into an auto easier then a manaul I have know idea why it just does!
71 SWB Stepside, was a 250, now is a 402 Big Block with 4 speed and 3.73's
72 LWB 4x4 350 4-speed 3.08's posi wearing army olive drab green (SOLD!)
68 BURB 50TH LOOKALIKE with built 350 4-speed 4.11's and posi
current project
67 402BB stout th350 3.08's with a locker. Plan on tubs 18.5's out back! (thanks Burnsman!)
71 SWB Stepside, was a 250, now is a 402 Big Block with 4 speed and 3.73's ( was crushed by a tree, bed sold, motor pulled) was my first truck!... oh well...
68 BURB 50TH LOOKALIKE work in progress, soon to have 250-I6 with a 3-speed on the tree 4.11's and posi ( currently sitting in back yard tarped awaiting time, $$$, and lots of love!)
67 1 TON- work truck 396 sm 420 4-speed, flat bed 4.57 gears "big red" (my first landscape truck, very rusty and crusty! but still gets the job done when needed!)
71402BB is offline   Reply With Quote
Old 03-25-2002, 09:30 PM   #8
71 K TWENTY
Post
make sure you used the right clutch, pressure plate, and installed the throw-bearing correctly. I had to reorder my clutch package twice, when I noticed they gave me one that was smaller and thicker!! put mine together about a month ago and went perfect, but I had the whole body off too, good luck!
FRAME OFF RESTORATION ON K-20 4X4, 1971.
71 K TWENTY is offline   Reply With Quote
Old 03-26-2002, 11:01 PM   #9
Blue_71
Bloo
Blue_71's Avatar
Post
its in my freind garage now, and tomarow we're taking out the motor and if we cant find anything wrong in there we're going to drop down the 4 speed and put in the auto. cant disengage the clutch, z-bar wont fit up right for some reason. thats why we just put it in neutral (i treid this with the 2wd and it worked...)never took the throw out bearing out, and used the same clutch that came from it. dont mean its the right one though i guess....... the guy i bought it from said the motor wouldnt work when he bought it so i just replaced the motor, and trraded off the one it came with. turned out to be 40 over pistons in a block bored 20 is why the original 350 wouldnt work. im really hoping to find something simple tomarow when we take the motor out but if not i guess its auto time. i dont really like suto at all but i really need this thing done by friday
J.B.
1989 Chevy K2500
Old 03-27-2002, 12:46 AM   #10
Scrub
Collector of rusty Items
Scrub's Avatar
Post
Pull the PTO cover off and have a peek inside. THat way you can twiddle a few gears around.
I'm thinkin' you got the throw-out bearing in front of the clutch fingers and when you pulled the motor on to the tranny, you put pressure on the back side of the clutch fingers. Getting everthing lined up is a bear. You definately need a lineup tool.
I made the mistake of replacing my pressure plate bolts one time. I discovered that the bolts that hold the pressure plate on are very special, sholdered bolts. I could not get it to line up at all.
Good Luck
Scrub
70 GMC 1,000,000 + miles
72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends.
Scrub
Sisters, Oregon - Home of the Sisters Rodeo.
Scrub is offline   Reply With Quote
Old 03-27-2002, 11:28 PM   #11
Blue_71
Bloo
Blue_71's Avatar
Angry
I CANT BELIEVE THIS!!!!!!! we pulled the motor forward, and guess what, the dumb*** didnt do what i told him and tighten the pressure plate bolts!! i told him i hadnt done it yet and he needed to, and he never did so when we pulled out the line up tool of course it slid down and we didnt notice it. but im putting the auto in anyways, when we got it out we found out the 4 speed is messed up. one of the ears that the bellhousing bolts onto had been JB welded on and when we took it apart it broke again and there was a big hole behind it. so in goes the TH350 and when money allows a lokar shifter to look like a stock 4 speed....
1989 Chevy K2500
