Old 05-16-2013, 09:18 AM   #1
jflem_also
31 gallon late model gas tank
does anyone have pics info on installing a later model larger gas tank in their burban?
pics and what has to move
going into a 3/4 ton 2wd -
When in Doubt ........ Mash the Throttle
69' Camaro SS LT1 - 6speed
71' C/20 Custom Deluxe Burban 402/400 now 454
72' C10 base burb 350/3on the tree
79' VW Scirroco Road Race Car
02' Suburban Supercharged 5.3 on 22's
jflem_also is offline   Reply With Quote
Old 05-19-2013, 08:39 PM   #2
Faster57
Junior Member
Re: 31 gallaon late model gas tank
I used a '73 30 or 31 Gal tank and it worked really well. I made two wood blocks for the tank to rest against reworked the neck to fit and made the rear strap brackets. the whole project took a good days work.
Faster57 is offline   Reply With Quote
Old 05-19-2013, 08:45 PM   #3
Faster57
Junior Member
Couple more shots.
Old 05-20-2013, 09:36 AM   #4
jflem_also
awesome pics!
I was planning on the same tank the 73-91 suburban 31 gallon
shows alot - I see you removed the crossmember did you weld one back inplase or just relocate?
Old 05-20-2013, 09:38 AM   #5
jflem_also
what did you do to re-work the neck I know the gas fill is different on the 73-up i was planning on rotating the tank?
Old 05-20-2013, 08:29 PM   #6
Faster57
Junior Member
It's been 4 or 5 years since I did the work but if I remember I just removed the crossmember and when I put in the wood blocks I used wood screws from the top to hold them in place. I put in the tank with the neck to the stock '71 position-to the left- The work on the filler tube was cutting it and rotating & bending it slightly to wave it line up with the tank inlet. I'll try to show the pictures of the tube.
