05-18-2013, 05:13 PM | #1 |
Having problems with lowering...
I am about to lower my suburban, but I have a problem. The front suspension is out of a 1977 Chevy half ton truck, while my rear suspension is stock. Will a lower spring kit for my '68 work with my front suspension? Or do I need to order different springs for the front?
-Holden 1983 & 1972 Chevy Longbeds (16) 67-72s (Rollback, 402's, Sierra Grande, Shortbeds, Shortsteps, Longhorn, etc) 1968 GMC Suburban- (Current project) Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=569806 (6) 60-66s (shortstep, rollback, two-ton, longbeds) (3) 47-59s half tons + MANY more and always looking for more |
05-18-2013, 05:42 PM | #2 |
Re: Having problems with lowering...
I'm not 100% certain, but I'll share what I THINK I know..... My 68 suburban front springs have a tighter-wound "D" opening at the top that specifically fits a "D" stamping in the top pocket....
I've lowered a couple of 73-78 era half ton trucks that had conventional wound springs in the front.... Based on this, it would be my opinion that if you are using the 77 crossmember, you would also need to use springs from that era.... I'm still not convinced that a 77 doesn't have a wider trac-width that a 67-72 because I have never been personally involved in such a swap or experienced the results first hand... |
05-19-2013, 07:21 PM | #3 |
Prestige Worldwide
Call the guys over at Early Classic Enterprises, they can get you set up with everything you need. They will even mix and match a kit to fit your application...
05-21-2013, 06:51 PM | #4 |
C10 Club Tennessee
The springs will work.
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
05-23-2013, 08:44 PM | #5 |
yes they will. the 73-87 does have a slighty different spring rate (stiffer i believe) over the 67-72.
Brian XNGH ECV Chapter 58 1972 Jimmy / Blazer Project 2wd 1974 Chevy Crew Cab Shorty |
