Old 05-21-2013, 12:42 PM   #1
Tkin496
Tkin496's Avatar
Show off your "Air Ride setup"
Im fixing to start the build on the 67 shortwheel & im looking for ideas for mounting the air tank, compressor, switches, ect. It has an original wood bed floor that i will raise up to componsate for the Porterbuilt setup in the rear but I would like to mount the air compressor and air tank on the frame somewhere out of sight but still look nice if someone looks underneath. If you have pics of your setup please post & since im a little new to the air ride it will help me out if you tell me what your running as well. im looking for something programable that will go to a certain ride hight when I want. I would like for something that i could maybe hide under the dash or in the glove box that all i have to do is push a button & she goes to the ground at a certain speed. (not to fast but before christmas to)
Tkin496 is offline   Reply With Quote
Old 05-21-2013, 11:32 PM   #2
Square_78
Square_78's Avatar
Re: Show off your "Air Ride setup"
Get Accuair eLevel. It's the best system out there for preset ride heights using sensor arms and not air pressure. Ride monitor modes and load leveling. I have their EXO mount system with dual compressors and 5 gallon tank. It's all bolted together in one unit and is mounted to the outside of my frame rail behind the cab and in front of the rear tires under the bed. The mount system also holds he ECU and air valve manifold all in one neat and tidy show quality package. I'd never do it any other way.
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline   Reply With Quote
Old 05-22-2013, 10:25 PM   #3
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Any mounted pictures square78?
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 05-23-2013, 09:56 AM   #4
Tkin496
Tkin496's Avatar
From what ive been reading accuair is the only way to go, Ive been looking and I like the way mike losh has his mounted on the inside of his frame and has his exhaust going into a single. I Definatly like the EXO Mounts. what do you attach the sensor arms to?
Old 05-23-2013, 07:29 PM   #5
stevencvn72
Kill Bill...et
stevencvn72's Avatar
Here's one. 4 gallon tank, Viair 444, accuair, 3/8" line and 7 switches all under the bed (eventually there will be some wood there) and out of sight.
-Steve
I Grease
'67 Chev stepper
http://youtu.be/38p_2Iu2fd0
stevencvn72 is offline   Reply With Quote
Old 05-23-2013, 10:54 PM   #6
king-918
king-918's Avatar
Posted via Mobile Device 86 swb can't decide where to install tank, thinking about where the fuel tank was
<----Christopher
Oh yeah I'm really a Toyota guy, but had some stuff sitting around.
Oklahoma
king-918 is offline   Reply With Quote
Old 05-24-2013, 06:23 AM   #7
wraprail
wraprail's Avatar
Dakota Digital DHC-2102 uses 4 height sensors and 5 pressure sensors (4 bags and tank pressure) has 3 presets and auto leveling plus adjustable speed settings front and rear.
Plus it cost less than the other guys and you know what your bag & tank pressures are.
Accuair valves of course.
York EDC. Quiet & Fast. So Fast.
Top quality and lowest cost air management
wraprail is offline   Reply With Quote
Old 05-24-2013, 07:32 AM   #8
72BlckButy
Tot Roddin'
72BlckButy's Avatar
So what do you figure you have tied up in this setup?
-Nate
Old 05-24-2013, 11:21 AM   #9
wraprail
wraprail's Avatar
For the air management only about $1575
accuair, air ride, viair
