Old 05-22-2013, 06:17 PM   #1
71ChevyJJ
Squealing at 60 mph
My 71 chevy squeals at 60+mph. Is this due to too high of gears or something more serious?
71ChevyJJ is offline   Reply With Quote
Old 05-22-2013, 06:19 PM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Squealing at 60 mph
Too vague of a post to answer realistically.
Where is the squeal coming from exactly?
It's probably a loose fan/alternator belt.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 05-22-2013, 06:25 PM   #3
71ChevyJJ
Checked the belts and the whole engine was gone through last year. It only happens when I push past 60 on the highway. I cannot replicate the sound otherwise to hear where it comes from. I think it is the gears but wanted a confirmation or denial.
Old 05-22-2013, 06:28 PM   #4
GASoline71
GASoline71's Avatar
Do you mean it's a high pitched "whine"??? That could be gears... or the transmission...
My truck only squeals when you sneak up behind it, and pinch the rear bumper...
Gary
Old 05-22-2013, 06:33 PM   #5
71ChevyJJ
I guess it could be a whine. It gets louder the faster I go and quieter when I back off the gas...
Old 05-22-2013, 06:34 PM   #6
GASoline71
GASoline71's Avatar
Check the basics first like tranny fluid, and diff oil.
Gary
Old 05-22-2013, 06:42 PM   #7
71ChevyJJ
copy that
Old 05-22-2013, 07:16 PM   #8
68gmsee
Active Member
68gmsee's Avatar
Could also be tires. One of my other vehicles has aggressive tread tires and they whine at certain speed and on certain pavements. Rear axle gear noise is a common problem with some trucks (mine included) and also tranny gears.
No sure way to identify it other than checking to see if the noise comes and goes when you let off the pedal. If it's tires the noise doesn not go away when you let off the pedal. If it's rear axle it will ease off. On the transmission, you can usually put in neutral to see if it stays or goes away.
Do some experimenting and see if the noise changes by doing the above. Maybe even go 60+ going downhill and let off the gas.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 05-22-2013, 07:34 PM   #9
SS Tim
SS Tim's Avatar
Could be a lot of things. From your history I'd say a good bumper to bumper inspection is needed and would be a good starting point. Do you have the service manuals for it? They can be downloaded here at this link.
http://67-72chevytrucks.com/vboard/s...d.php?t=558016
SS Tim is offline   Reply With Quote
gears, squeal
