Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 05-27-2013, 11:42 PM   #1
1972K20
1972K20's Avatar
Basic Tools Needed for Rust Repair?
What the basic list of tools needed for patch panel repair? What type of grinder is recommended for removing paint? What's best for making cuts in the sheet metal?
Thanks!
1972K20 is offline   Reply With Quote
Old 05-28-2013, 06:54 PM   #2
chevy88
chevy88's Avatar
Re: Basic Tools Needed for Rust Repair?
Cuts it sheet metal or cutting out rust I use a 4 inch grinder with a zip cut 1/8 or thinner blade, a mig welder is best but I settled for a flux core welder when weeding new pieces in, for removing paint around 80 grit removes it quick with flex pad on grinder with flexible metal oxide pads. This should get you started, check out my build thread I had to deal with enough rust.
Kerry
My build thread.
http://67-72chevytrucks.com/vboard/s....php?p=3657823
1971 Chev SWB with 68 nose, 6.2 diesel th350, and 3.73 rear gears
1988 Chev Extendacab
2010 Honda VT1300CS Sabre
2005 Buick Rendezvous wife's ride
chevy88 is offline   Reply With Quote
Old 05-28-2013, 07:58 PM   #3
1972K20
1972K20's Avatar
Thanks!
