Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 07+ Chevy and GMC Message Board
Old 05-30-2013, 08:00 PM   #1
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Any 6.2L owners?
Curious if there are any 2007-2013 6.2L 1/2 ton owners on the board.
Are you guys happy with them?
What rear gears are you running?
5 spd or 6 spd transmission?
What kind of MPG are you getting?
Are you happy with it?
How's the towing capacity?
Thanks for any info you can provide.
Nate
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 05-30-2013, 08:53 PM   #2
clinebarger
Re: Any 6.2L owners?
The 6.2L/6L80E combo tow's very well.
Fuel mileage leave's a lot to be desired....400hp truck's don't get good MPG, But 5.3L 1/2 ton 4x4 Crews aren't that good either.
Dropping the 4wd for a 2wd, & a really good custom tune will put you pretty close to what you get now.
clinebarger is offline   Reply With Quote
Old 05-30-2013, 09:20 PM   #3
72BlckButy
Tot Roddin'
72BlckButy's Avatar
So a 6.2 would be closer to 10 MPG daily driven or are we talking worse?
-Nate
Old 05-31-2013, 10:34 PM   #4
mitchntx
I picked up a 13 GMC with a 6.2/6L80E and 3.73 gears.
AFM takes a little ... a LOT ... to get used to. Lots of shifting up and down on hills, apply throttle and it's rather jerky and even from a take off, it's hard not to lurch forward.
Rides great, although it could use better shocks ...
I've just run 3 tanks through it, but the lie-o-meter on the dash says 14mpg avg. My routine is probably 75% rural roads ...
And holy crap ... mashing the loud pedal plants you in the seat ... pulls as hard as my 6.2 CTS-V.
mitchntx is offline   Reply With Quote
Old 06-01-2013, 06:50 AM   #5
72BlckButy
Tot Roddin'
72BlckButy's Avatar
I'm worried about possibly upgrading to the. 6 spd transmission due to the shift points, especially when towing.
Thanks for the info.
-Nate
Old 06-01-2013, 09:06 AM   #6
mitchntx
I haven't towed anything yet, so I have no first-hand experience.
But when I select Tow/Haul mode, it acts like I remember my 8.1/Allison acting. Shift points are extended up the RPM range and delayed quite a bit on the downshift.
Also, the trans selector can be taken from "D" to "M" and there is a toggle button on the shifter which turns into a manual, sequential shifter. I have discovered that while on the road, selecting "M" and 5th gear it seems to lock the convertor and by-passes AFM logic and the rig runs on all 8 cylinders.
Old 06-11-2013, 12:45 AM   #7
SeTx67
SeTx67's Avatar
Just sold my 6.2/6l80e with 3.73s. I never towed much with it but when I had a few light loads it performed well. According to the dic I was averaging 14 combined city/highway. I had longtubes, true duals, cai and a tune. For a crew cab it would move
SeTx67 is offline   Reply With Quote
Old 06-11-2013, 08:51 PM   #8
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Thanks for the info. I've heard they will move down the road quite well.
-Nate
Old 06-27-2013, 03:45 PM   #9
MadManAndrew
You can turn Active Fuel Management off in the DIC. I've never noticed a problem with it, though. Mine only deactivates cylinders when I'm coasting. As soon as I touch either pedal all 8 come back on.
1955 Chevy 3600 http://67-72chevytrucks.com/vboard/s...61#post8589061
MadManAndrew is offline   Reply With Quote
Old 07-09-2013, 11:16 AM   #10
N2TRUX
Happy to be here
N2TRUX's Avatar
Nate I have never owned a 6.2 truck but I am on my second 6.2 powered Denali. I can tell you that there is plenty of power for towing. I have had no issues with the 6 speed in shifting loaded or unload. In tow/haul mode the trans brake seems to be rather over active at times but its a flick of the switch if you think its over revving the motor.
Having had several Yukon XL's I can attest that the 6.2 powered Denali was the best performing full size SUV I have ever driven. I actually got decent mileage from it with out a tune. I did have a GM intake, but no tune and managed 18mpg on the road with no load.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 07-11-2013, 05:06 PM   #11
Cole Trickle
C-10 Club Member
Cole Trickle's Avatar
I have owned/driven quite a few 5.3 trucks over the years
03
05
07
09
13
The 09/13 both have the 6 speed auto and are leaps and bounds better than the older 4 speeds. There faster and always have a gear for towing or passing. They also get better mpg.
The 6.2 is a nice motor with a ton of power. MPG won't be great but it's alot more fun to drive than the trusty 5.3. There also alot harder to find and the price jumps significantly as there typically loaded up.
I chose the 5.3 again as they have treated me well. I was slode to pulling the trigger on a new ecoboost equipped f-150 (the interior is nicer and they haul ass) but the 10K off sticker on my 13 was too hard to pass up.
For around town and towing say 7K pounds and under the 5.3 does a good job. If I was towing heavier than that I would probably own a diesel.
1969 Short Fleet 350/SM465 4.5/6.5 ECE drop 20" Raceline Wheels
1998 2dr Tahoe 5/7 drop 20"/22" Coys-sold
Build thread...http://67-72chevytrucks.com/vboard/s...d.php?t=401910
Cole Trickle is offline   Reply With Quote
