Old 06-05-2013, 12:27 AM   #1
Fatolbaldguy
Fatolbaldguy's Avatar
Alternator How Big? AMPS
I am just about finished installing my air conditioning kit into my 292 65 3/4 ton C20. Some hoses still need to be fitted and some holes in the firewall need pluging.
On the test drive I discovered that the tired old alternator can no longer keep up with the load. It barely managed before I put AC in. I realize that I need to swap in a new high output alternator but how big? How many amps? How do I determine whats best. I'd rather not take it into the shop since this project is way over budget and getting worse. Thanks
Fatolbaldguy is offline   Reply With Quote
Old 06-05-2013, 01:33 AM   #2
Rufton
Re: Alternator How Big? AMPS
Sorry for the lack of helpful substance:
Are the wires terminals in good shape.
The last time I purchased alt I just bought largest available at reasonable price. Without knowing specs and doing the math I'd guess alt amps on modern truck should be more than sufficient.
Rufton is offline   Reply With Quote
Old 06-05-2013, 08:52 AM   #3
McCoyAZ
McCoyAZ's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=119379
this link and mod can be doe for about 30-40 buxs for an 80-90 amp alt
McCoyAZ is offline   Reply With Quote
Old 06-05-2013, 09:33 AM   #4
Fatolbaldguy
McCoy AZ the link doesn't work! 404 error. I would love to see what it says. Thanks
Old 06-05-2013, 10:11 AM   #5
McCoyAZ
McCoyAZ's Avatar
Sorry about the link.....it's one I had asked the same question you did and now I guess it has expired.
Old 06-05-2013, 10:13 AM   #6
luvbowties
luvbowties's Avatar
Smile Re: Alternator How Big? AMPS
Pretty informative site u may want to read. Keep in mind ALWAYS that member "Woogeroo" has some great sites listed on all his threads--look at new threads of his as well.
HTH,
Sam
>> http://67-72chevytrucks.com/vboard/s...d.php?t=375560 <<
luvbowties is offline   Reply With Quote
Old 06-05-2013, 11:53 AM   #7
gofastnut
gofastnut's Avatar
I had the same trouble with a buddy's truck. We went with a 7127-1W (1 wire) and it couldn't keep up with the AC being on.
I did a little checking and found a 7294-1W (1 wire) is more amps earlier in the RPM range and overall.
These are Endurance brand part numbers, if you don't use 1 wire, just substitute the clock position you want in the last number, ie: 7127-3, 7294-12, etc.
Oh, the 7924 case has the same overall dimensions as the popular 7127 case, just higher amp.
Hope this helps!
Jeff
96 C3500 Crew Cab Long bed (Waiting on Cool Name)
64 C-10 shortie stepside, "Ole Brownie"
C-10 Club
My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345
gofastnut is offline   Reply With Quote
Old 06-12-2013, 05:07 PM   #8
gofastnut
gofastnut's Avatar
Any news?
Jeff
C-10 Club
Old 06-12-2013, 08:46 PM   #9
corvettejim1968
corvettejim1968's Avatar
have it rebuilt by Gen Star they did mine it went from 45amps to 90amps been in buisiness since 1964 they are at 63rd ave and Glendale i have used them since 1991 this way you get your original back too.623-939-2202
Hand Made Factory reproduction A/C vents
text or call 602-361-6421
Website for A/C vents
https://coolc10.com/
corvettejim1968 is offline   Reply With Quote
Old 06-12-2013, 09:19 PM   #10
brokenspoke
brokenspoke's Avatar
check out " madelectrical" lots of great info on this subject
brokenspoke is offline   Reply With Quote
air conditioner, alternator
