Old 06-24-2013, 07:36 PM   #1
burton'sblazer
burton'sblazer's Avatar
A/C woes for 2004 silverado
Any A/C buffs around? My compressor locked up on my '04. What would be the way to fix? Pull compressor and flush system?
burton'sblazer is offline   Reply With Quote
Old 06-24-2013, 08:15 PM   #2
truckdude239
truckdude239's Avatar
Re: A/C woes for 2004 silverado
Pull conpressor flush system replace the receiver drier anf offrice tube. Dobyour self a favor and buy a new compressor from napa i installed a reman from advance auto for a customer cause thats what ahe wanted it disnt last 2 hours before the clutch fried off
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 06-24-2013, 08:21 PM   #3
burton'sblazer
ok, that's what I figured. What would you use to flush the system out with?
Old 07-04-2013, 11:37 PM   #4
sleepertruck72
sleepertruck72's Avatar
There should be flush kits available, I used one where I had to pour into a separate bottle and pressurized with shop air... flush through, add oil to accumulator if needed, install orifice tube. Make sure to drain oil from compressor and charge with correct amount and type of oil. If possible replace any O-rings at the block fittings to help prevent leaks. Pull vacuum and charge if no vacuum leak is found.
72 C20 Longbed
05 1500 Z71
sleepertruck72 is offline   Reply With Quote
Old 07-05-2013, 12:13 PM   #5
MadManAndrew
NAPA will be twice the price of other Auto parts stores. You can get a brand new Delphi compressor with clutch from Autozone for $340. Same compressor is over $600 at NAPA.
1955 Chevy 3600 http://67-72chevytrucks.com/vboard/s...61#post8589061
MadManAndrew is offline   Reply With Quote
Old 07-05-2013, 01:27 PM   #6
truckdude239
i used the napa cold power kitys never had any problems with there aftermarket compressors, if you want to go back with dephi be prepared to spend some money
David fuller
2000 Tahoe 5.3l 378
Old 07-08-2013, 10:53 PM   #7
MadManAndrew
If this thread is otherwise done, I have a related question. I have a brand new compressor, accumulator, and orifice tube, and today I charged my system to 60 psi when the ambient temp was about 100*F. It blows ice cold, but the problem is that it still cycles off frequently when I'm driving. I can constantly feel it going from cold to warm about every 30-45 seconds. At idle, it stays on and blows cold. What the hell do I need to do?
Old 07-08-2013, 11:24 PM   #8
sleepertruck72
Charged to 60 psi ? How much refrigerant did you charge into the system? Did you flush the system, pull a vacuum before recharging ?
72 C20 Longbed
05 1500 Z71
Old 07-08-2013, 11:55 PM   #9
truckdude239
60psi omg!!! Pressures should be around 35-45 on the low side and 175-250 on the high side. If you charged to 60 psi your more then likey hitting the high pressure out off on the high side
David fuller
2000 Tahoe 5.3l 378
Old 07-08-2013, 11:57 PM   #10
truckdude239
Also its better to let a shop charge it with a machine they can add the proper ammoit of frenon that the manufactor recomends
David fuller
2000 Tahoe 5.3l 378
Old 07-09-2013, 09:17 AM   #11
67ChevyRedneck
67ChevyRedneck's Avatar
Rockauto.com carries both Delphi and delco compressors for around ~$200.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 07-09-2013, 10:19 AM   #12
MadManAndrew
Even with the ambient temp around 100*F? At 40 PSI my air was not very cold.
Old 07-09-2013, 10:27 AM   #13
MadManAndrew
Okay, so my actually pressure 57 PSI and everything I can find says at anything over 90*F low side pressure should be 50-55 PSI. I'm pretty spot on. If I release refrigerent will it be more difficult for the compressor to pull it down?
a/c, compressor, flush system
