03-26-2002, 11:55 PM | #1 |
RPMS???
what should the rpm be at idle??
thanks in advance ------------------ http://68chevy0.tripod.com/68stepside/ 68 Chevy c10 swb stepside 3/5 drop sbc 305/700r4 tranny 3:07 rear gears 17x8 eagle alloy wheels Pikeville,Kentucky
http://68chevy0.tripod.com/68stepside/ 68 Chevy c10 swb stepside 4/7 drop sbc 305 edlebrock performer camp/intake/600cfm ec carb 700r4 tranny 3:07 rear gears 17x8 eagle alloy wheels Pikeville,Kentucky |
03-27-2002, 12:01 AM | #2 |
i run mine between 600 and 800 rpm, but it kind of depends on how big a cam your running
sometimes to much idle will give as bad of a hesitation as not enough
70 3/4 ton 4x4 FOR SALE Greene, IA |
03-27-2002, 12:15 AM | #3 |
Formerly yellow72custom
I like mine at about 700 (roughly) in Park, and 550 in gear. It won't die, and sounds pretty good too. I have a 350 with a small cam and a automatic tranny. I think the stock setting is 600 in gear for my '72, but im not sure....
------------------ Lucas "Another proud owner of one of the coolest trucks ever built" drop_shift@hotmail.com My Daily-Driver: '72 Chevy LWB Custom/10. Rebuilt 350, 300 HP thanks to a few go-fast goodies. Ochre with a white top. Future plans include a frame off restoration, and maybe a blown 383.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
03-27-2002, 12:31 AM | #4 |
my truck is running 1000-1100 at idle any idea why so high? i have a sbc 305 with edlebrock performer cam/ intake/ and 660cfm carb any chance the tach can be wrong its aobut 13 years old
03-27-2002, 01:05 PM | #5 |
ttt
------------------ http://68chevy0.tripod.com/68stepside/ 68 Chevy c10 swb stepside 4/7 drop sbc 305 edlebrock performer camp/intake/600cfm ec carb 700r4 tranny 3:07 rear gears 17x8 eagle alloy wheels Pikeville,Kentucky
03-27-2002, 01:11 PM | #6 |
Got 20's????
just turn down the idle screw
99 Silverado Ex-Cab 2wd, Bagged&WhippleCharged 02 Sierra Ex-Cab 4wd 2500 HD The 72 went down the road. |
03-27-2002, 01:16 PM | #7 |
oh yea i forgot to mention it wont idle it acts like i need to turn up the idle screw when i put it in gear and it dies also but when it does idle its at 1000 to 1100
------------------ http://68chevy0.tripod.com/68stepside/ 68 Chevy c10 swb stepside 4/7 drop sbc 305 edlebrock performer camp/intake/600cfm ec carb 700r4 tranny 3:07 rear gears 17x8 eagle alloy wheels Pikeville,Kentucky [This message has been edited by 68chevy (edited March 27, 2002).]
03-27-2002, 01:21 PM | #8 |
Smaller engines have a higher idle. Some V6 engines are set to 1000. Same with 4 cl. engines. I've always heard that automatics should be set to 800. That's what mine's set to.
------------------ '69 3/4 ton C20 2wd w/ 350ci/400THM and a wood bed! '69 3/4 ton Custom 20 2wd w/ ORIGINAL 350ci/4sp Manual and a wood bed (parts beast). Seattle, WA. *See pics of my trucks and project at www.webshots.com!
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. |
03-27-2002, 03:03 PM | #9 |
When my 69 was a 2wd I had a 327 with a 700r in it, a performer intake with a 650cfm holley and the biggist cam you can get. My problem was to get it idle and not to die when I put it into gear. The problem was that the jets in the holley weren't the right size. So what I think you should do is take it in to a performance shop and tell them what going on and get them to fix it. The cost for me to get this done was roughly about $100.00 Canadian Dollers and man it had more power and it didn't die every time I put it in to gear.
Hope this helps and Good Luck ------------------ 1969 Chev 4x4 9" of lift,327cid,38/16/16.5 Super Swapers,Factory Tack,Powder Coated almost everything.
1969 Chev 4x4 9" of lift,327cid,38/16/16.5 Super Swampers,Factory Tack,Powder Coated Frame and other misc. Calgary, Alberta, Canada |
03-27-2002, 11:02 PM | #10 |
a radical cam can cause an engine to die at low rpms
03-28-2002, 12:10 AM | #11 |
just a thought, try putting the vacuum advance on the un ported vacuum...this will bring in your advance at idle..thats what i did for mine, and i have a slightly bigger cam than you
------------------ 67 lwb fleetside...first hotrod in 25 years...283..186 bowl ported heads..270h comp cam 600 1405...stealth intake..HEI..th350 with 2500 rpm stall..4:10 POSI god I love to go fast
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
