Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork > Detailing
Old 07-06-2013, 06:08 PM   #1
Damon23
Damon23's Avatar
Detail Clay not working
I have a spot on the rear of the passenger side bed. Looks like some sort of paint. It looks like paint hit it or maybe even some clear. I don't know but I used a clay bar and it is not getting it off. Any other suggestions?
Experience is something you gain when you didn't get what you wanted in the first place.
No great defeat was ever just possible in the beginning.
Damon23 is offline   Reply With Quote
Old 07-16-2013, 08:44 PM   #2
2ndstoryslam
2ndstoryslam's Avatar
Re: Detail Clay not working
WD-40. Grease and Wax Remover. Light 3M 6068 polish by hand. Mothers Mag polish by hand.
2ndstoryslam is offline   Reply With Quote
Old 07-17-2013, 04:03 PM   #3
Damon23
Damon23's Avatar
Tried the wd-40, wax and grease remover and the mag polish. I was out of the perfect it 2 compound. I need to see if they can give me a paint code anyway so I'll go get some. Thanks.
Old 07-17-2013, 09:22 PM   #4
Rochlow
2000 ultra fine and perfect II
///Relaxed Atmosphere
Rochlow is offline   Reply With Quote
Old 07-20-2013, 10:25 PM   #5
BigDan3131
BigDan3131's Avatar
Did you think to just lightly soak a rag in Laq Thinner and wipe it off???
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 07-21-2013, 01:15 PM   #6
Chrome8
Chrome8's Avatar
I took a new truck to the body shop to have a clear coat drip fixed and the guy put a piece of tape on a razor blade and carefully shaved it off! I couldn't believe it, must be an oldtimer trick or something. We buffed it and it was virtually gone.
Chrome8 is offline   Reply With Quote
Old 07-31-2013, 10:27 PM   #7
BigDan3131
BigDan3131's Avatar
I do that all the time it just takes a knack to know when to stop.
Old 07-31-2013, 10:35 PM   #8
Rufton
Detailing clay can lift paint if used aggressively.
I like Rochlow's idea but those supplies are expensive.
Rufton is offline   Reply With Quote
Old 02-12-2014, 04:15 AM   #9
v6wells
goof off
v6wells is offline   Reply With Quote
Old 02-12-2014, 07:46 AM   #10
piecesparts
Parts and more parts
piecesparts's Avatar
You can purchase a fine grit wet and dry paper in any paint supply outlet and the rubbing compound is easy enough to get. If you don't want to pay for the quart of quality rubbing compound, then purchase some small containers from O Reillys or Autozone, that is used for rubbing out paint. If all else fails use toothpaste, it is an abrasive.
I use 3M Finnesse-It rubbing compound in my shop all of the time for rubbing out paint scratches, fogged over headlights, scratched plastic lenses, instrument gauge panels, and just about anything that has something stuck to it. It is not expensive if you use it all of the time.
Frank
piecesparts is offline   Reply With Quote
Old 03-06-2014, 04:27 PM   #11
Iceburgh
Iceburgh's Avatar
There is some info here that I would stay away from.
Best thing to do is post a pic to get a better look at it along with some info about the type of paint used.
Iceburgh is offline   Reply With Quote
Old 03-06-2014, 10:18 PM   #12
piecesparts
You could clarify this some more???????
Frank
Old 03-07-2014, 02:57 PM   #13
Iceburgh
Iceburgh's Avatar
I would never use thinner to remove overspray. You might get away with it with enamel but lacquer or base coat clear coat you wont. Not even lightly,
Clay never will lift paint. Not the mild clay , not the aggressive clay.
If it does it is a paint issue not a clay issue.
If the problem is actually over spray and not something like the clear breaking down, clay will work. If it does not sand and buff is your next option.
In this case lighter is better not knowing what you are working with as far as thickness of paint, age etc.
Start out with 5000 wet, rotary medium cut ( numerous brands) with foam pad at 1500 rpm. Move to light cut then on to D.A. with finish
Old 03-07-2014, 08:53 PM   #14
piecesparts
Thanks, nothing like the whole input.
Frank
Old 03-07-2014, 09:44 PM   #15
Gumby
Gumby's Avatar
Did ya try some gas on a rag? will strip the wax in the area but if the paint that got on it, was still soft or didn't bond well, it should come off. Just wax the area when done.
Chevy GMC Trucks Find Of The Day
https://www.facebook.com/ChevyGmcTrucksFindOfTheDay or http://ChevyGMCTrucks.com
Gumby is offline   Reply With Quote
