03-27-2002, 08:31 PM | #1 |
which is the # 1 cylinder?
sorry for the silly question. i remember on my buick 350 the #1 cylinder was on the driver side closest to the radiator. my truck doesnt have any numbers on the manifold, plug wires or distributor.
its a 72 with a 350. also do i have to disconnect the vacuum when i set the timing?
Blake A. - Huntington Beach CA 72 c10 swb 5/5 drop, 350/350, partialy shaved, soon to be 5/7 on 20s. |
03-27-2002, 08:34 PM | #2 |
Shortbox wanna-be.
#1 on a 350 is the drivers front.
And yes you have to disconnect the vacuum line going to the distributor AND PLUG IT. Drivers--------Passenger #1.............#2 #3.............#4 #5.............#6 #7.............#8 ------------------ Sylvan Lake, Alberta, Canada 1970 Chevy C20 Custom Camper #s matching 402BB Turbo 400 trans. Air conditioning, power steering, manual brakes. 73,600 Original Miles!! [This message has been edited by REPO1 (edited March 27, 2002).]
1970 Chevy C20 Custom Camper 402BB Turbo 400 trans. (Slowly becoming a '70 shortbox 1/2 ton) '71 Camaro SS 402/T400 resto '97 Z28 (11.41@127MPH) |
03-27-2002, 08:35 PM | #3 |
Front ,drivers side....69 longhorn
http://community.webshots.com/user/hotrodhorn |
03-27-2002, 08:37 PM | #4 |
the number one cylinder is on the driver side closest to the radiator
03-27-2002, 08:53 PM | #5 |
ok when i hooked up the timing light to that cylinder and flashed the little points on the balance no mark showed up. i turned off the truck and found the groove in the balancer.
so what gives? the marks completely not lined up with the little timing points. it seems to run pretty good so its not like it could be off that much. how do i go about finding out where the mark should be?
03-27-2002, 09:00 PM | #6 |
should i just set the 1 cyl to top dead center then make a mark on the balancer to point at 0 or top dead center
03-27-2002, 09:24 PM | #7 |
is your mark on the balancer white if not try using white-out on it and it will show up when you shine the light on it.
03-27-2002, 09:58 PM | #8 |
Old member
No do not remark it. Take the distributer loose and crank the engine and set it to about 6 degree's are 8 before top dead center. That should put you in the ball park. If you have a tach, you will want it to be around 6000, or 7000 with straight drive. If you have a automatic and air it should be around 8000, so when you turn the air on, it want die. You may have to reajust your idle speed to do this. Hope this helps. Andy
------------------ Andy 71's Are for ever!!! or 67,68,69,70,72 http://geocities.com/chevy71tpi/main.html
03-27-2002, 09:58 PM | #9 |
always remember #1 is the head sitting farthest foward on the block
------------------ 70 short step from vegas woo hoo !!!Ken Lyons Slippery Rock PA yahoo messenger:mooneyes4b "things always look different from higher up" Clint Eastwood (fist full of dollars)
Ken Lyons, Slippery rock pa 68 short step 327 t10 4 gear 72 2wd blazer project 70 lwb 305/700r driver 78 caprice project 02 cavalier D.D ( hate it!!) |
03-27-2002, 10:03 PM | #10 |
its all about the +6 inches
Take a zero off of andy's numbers up there... don't wanna put a window in your block.
------------------ '69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it. Need to pick up the one ton Longhorn with a PONTIAC 350/350soon. Thanks every one! Check out The Longhorn Webite. If you need a pic posted, E-mail me at longhornmail@yahoo.com Andy, in Columbus Ohio |
03-27-2002, 11:12 PM | #11 |
I am a Referee of life.
You will not see the timing mark if you haven't disconnected the vacuum.It will be advanced too much.Marking the groove on the balancer with white is the only way this old fart can see the mark anymore.I got a great timing light with a dial back feature that lets me see how much advance I have at any given engine speed.(God Bless Great Wives.)
------------------ Deland does Chevys 68Chevy panel(LIZ) "A man and his truck,it's a beautiful thing" "I have the body of a god,unfortunately it's Budda"
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
03-27-2002, 11:44 PM | #12 |
drag racer
PanelDeland is right..If you buy a new timing light, get the type that has the dial on the back that allows you to adjust it to the amount of advance you want to run and set the timing to 0 on the balancer.
for example ( I run my drag car timing 43 degrees advanced. I adjust the knob on the back of my timing light to 43 so that when I have the car running and the timing light pointed at the balancer/pointer, the timing pointer is at 0 when the timing light flashes.) This way you can see the mark on the balancer when the timing light flashes.. 67chevelle ------------------ Current rides: 01 GMC 2500 SB HD CC 4x4 8.1 allison 67 Chevelle drag car 509 CI BBC,TH400 9.850 @ 134.55 mph 1970 C10 2WD PU being rebuilt 1967 El Camino 396, TH400 ( wife's drag car) Jr. Dragster 5 hp B&S for the kids http://community.webshots.com/user/mark67chevelle
Current rides: 01 GMC 2500 SB HD CC 4x4 8.1 allison 67 Chevelle drag car 516 CI BBC,TH400 9.777 @ 138.4 mph 1970 C10 2WD PU being rebuilt 1967 El Camino 502, TH400 ( wife's drag car) Jr. Dragster 5 hp B&S for the kids |
03-28-2002, 12:11 AM | #13 |
lol, that got complicated in a hurry, i say just connect a vacuum gauge to the engine and adjust everything until have 18-22 Hg and then make sure you have no ping under load(acceleration in gear, caused by too much advance, turn distrib clockwise to fix) and no hesitation with hot restarts(caused by too much retard in timing, turn distrib counter-clockwise to fix)
good luck |
