07-22-2013, 06:06 PM | #1 |
is this a 307,327 or a 350 ? please help
ok so i have a few casting numbers please help me out..
crank # 3911001 front left of the block 781122502 VII29HF block casting # back right 3914678 can you tell from this or do i have to measure the stroke? i was told its a 327 but i dont see the valve at the back of the block like the 383 has, i have a 283 so i looked. also the web or ridge isnt on the front left ....so what more do i need to know what ive got??? if it is a 327.... then i have a 283,327,350 and im looking to build a motor for my 51 bel air ...i would love to have it good on gas and i really like the sound of a lumpy cam ..Big Muthr Thumpr.. can i have both?? what should i build for this car ..ive never built a motor and i think its about time ,thanx for all the help.. and let me know if i can help by looking for more casting numbers..all the sites i look at say its one of the 2 but i want to know if it is a 327 |
07-22-2013, 06:19 PM | #2 |
identifying 307,327,350?
trying to find out what motor i have if anyone can help that would be great
casting numbers i have are crank #391001 block casting # 3914678 block code 781122502 VII29HF do i have to measure the stroke to know if this is a 327 or what numbers do i need to look for ...i dont see the valve at the back like the 283 has and i dont see the "web" or "fin" at the front below the head so if you can help me out or let me know what i have here or what i need to tell what i have that would be great ...thanx for the help... |
07-22-2013, 06:35 PM | #3 |
Re: identifying 307,327,350?
sorry for the second thread the first one didnt look like it stuck.. sorry
07-22-2013, 06:46 PM | #4 |
Ive merged your threads please try to be more careful
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
07-22-2013, 06:47 PM | #5 |
oh cool thanx man
07-22-2013, 07:12 PM | #6 |
is a fungineer
Looking at the overlap on the dates, I'd bet it's a '68 327.
3914678 302/327/350 68-79 210-350 car & Truck 2-bolt 3911001 307/327 68-73 2.45/2.10 3.25 Nodular Iron HF 65 327 Corvette 300 L-75 Manual 4-Brl AFB Carter HF 66 327 Impala 275 L-30 Power glide 4-Brl Hyd Cam, A.I.R. HF 67 327 Impala 275 L-30 Power glide 4-Brl Hyd Cam, A.I.R. HF 68 327 Impala 275 L-30 T-H 400 4-Brl Hyd Cam HF 69 350 Nova 250 L-65 Power glide 2-Brl Hyd Cam HF 69 350 Chevelle 250 L-65 Power glide 2-Brl Hyd Cam HF 69 350 Camaro 250 L-65 Power glide 2-Brl Hyd Cam HF 78 350 Pontiac 170 LM-1 TH 350 4-Brl Hyd Cam, Firebird
2003 S10, 2.2 auto- the daily driver, currently with a 2"/2" drop and some minor engine bolt-ons 1978 Impala 2-door, race 350/T350 - the new race car, in progress 1968 Chevy C10 longbed- 3/5 drop, currently undergoing a heart transplant |
07-22-2013, 09:49 PM | #7 |
sounds great...so from what ive read the vortec heads seam to be a good choice for fuel and power ..i want to put this motor in my 51 bel air ..looking for a little power,good on gas,and if i can a lumpy cam,i love that sound.. what is the best way to go with this motor to get everything i want out of it?
07-22-2013, 10:02 PM | #8 |
i like the sound of the mutha thumpr...and the big mutha thumpr cams ...i want one will it be bad on gas what do i need to make it all work?
07-23-2013, 07:59 AM | #9 |
Those thumper cams are junk
07-23-2013, 10:54 AM | #10 | ||
"I ain't nobody, dork."
Yup... all sound... they are ground that way. There are waaaayyyyy better cams out there.
Look into the Lunati Voodoo series or Comp XE series. Gary Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
07-23-2013, 11:17 AM | #11 |
*** That's interesting ***
Yep, thumper is all bark and no bite. Can't go wrong with a Lunati Voodo. The Comp XE is good too. Just get the right profile that will give you some lope if that's what you want. Use the Comp website or ask around here what cams others use.
Tom Chevy by day... 1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E 2011 Chevy Caprice PPV 9C3 6.0L 1995 Chevy Caprice 9C1 1994 Chevy Caprice 9C1 #3 1995 Chevy Caprice Wagon #2 1995 Chevy Impala SS Mopar by night... 1969 Dodge Charger 1972 Chrysler Newport 2dr Hardtop (27K miles) Plus others... |
07-23-2013, 11:27 AM | #12 |
thanx for the heads up guys..
07-23-2013, 12:10 PM | #13 |
Howards makes some good stuff too
07-23-2013, 11:15 PM | #14 |
just got a set of 350 vortec heads casting #12558062 for 150$ and only costs 25 to have them fluxed... so the 1951 bel air is being built from the ground up, i still dont have a rear end in the car so can get any gears still... what cam and gear set should i get to make this thing drive good in town but still be have lost of go...ill do whatever it takes to make this work..new springs in the heads to get a more lumpy cam ... ive never built a car to go fast..only just added any sbc i had around and put a intake on...prob the wrong ones lol anyways would love some help with this. thanx
07-24-2013, 10:27 AM | #15 | ||
Call the cam companies. Tell them what you have and what you want to do. What you think is "streetable" and what I think is "streetable" isn't even going to come close.
Gary
07-25-2013, 07:00 PM | #16 |
No No
It depends if its going into a bel air I would rather have a cam to give me a little more bottom end rather then higher top end unless this is going to be a drag car 3896929 is the crane number for the 300hp 327 cam. always a good choice IMO for a street driven car.
1976 Custom Deluxe SWB Med FMB.3/4 Drop. Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out. 1997 K1500 ext cab 5.7 stock except muffler |
07-26-2013, 01:34 AM | #17 |
thanx for all the info guys. im building this car for the street. wouldnt mind blowing the doors off a few cough cough you know the f word. but i want to have this as my D.D ..
07-26-2013, 01:39 AM | #18 |
big cams arent fast.. especially with vortec heads.. use a 60102 at most and a shim.
-'73 c/10 - Low with Go - will be complete... probably never. -'90 2wd Blazer - well... soon enough anyways. -'84 SWB - the daily gas guzzler. |
07-26-2013, 10:18 AM | #19 | ||
I'm not a big fan of Vortec heads... but if you're lookin' for a mild street build with a cam that has under .470 lift they are pretty darn good. Just remember you will need a special intake to bolt to Vortec heads.
Gary
Tags |
327, casting numbers, crank, sbc |
