Old 07-24-2013, 10:45 AM   #1
MyDad'sTruck
Will this "new" Rockwell 221 fit?
I have found a transfer case to replace the one I have, but the adapter is different from mine, as is the shifter thingamajig. The new one is from a 67 3/4 ton truck that had a SM465 and a 327 motor which is the same as in my 68. Will the "new" one bolt in to my adapter? If nothing else, i could rebuild using one for parts? Mine is the one in the truck. THANKS!
MyDad'sTruck is offline   Reply With Quote
Old 07-25-2013, 09:18 AM   #2
Yukon Jack
Post Whore
Yukon Jack's Avatar
Re: Will this "new" Rockwell 221 fit?
I'm not aware that different versions of the T221 were produced - the only difference I'm aware of is with the adapter. I'm pretty confident you can bolt that tc to your adapter. You'll be able to swap the shifter linkage from your tc to the new one if necessary.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 07-25-2013, 07:59 PM   #3
MyDad'sTruck
Thanks. I appreciate the feedback and plan to make an offer.
Old 08-03-2013, 08:17 AM   #4
MyDad'sTruck
Angry Re: Will this "new" Rockwell 221 fit?
i purchased the TCase and tranny as a unit. The seller didn't want the tranny so it came with the TC. I took every bolt off the adapter that holds it to the TC but i cant get them apart. What am I missing? What else do I have to do to separate the units? Do i have to remove the front or rear input or output shafts?? BTW the cases are both filled with oil and seem to shift easily. i am making this up as i go, so i appreciate any help i can get!
Old 08-03-2013, 10:24 PM   #5
snj8198
snj8198's Avatar
There should be 8 bolts total from T-case to adapter plus the shifter linkage. If you're positive that you have that disconnected then try shocking the case and adapter with a rubber mallet. Smack away at different areas and it should unstick.
Good luck.
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
Old 08-05-2013, 10:34 AM   #6
MyDad'sTruck
I got the T-case separated from the tranny and the adapter! That was a relief. I can see that this one is in better shape than the one on my truck now. What is a good place to find gaskets for this T221??
Old 08-05-2013, 08:02 PM   #7
Yukon Jack
Post Whore
Yukon Jack's Avatar
Not sure of whether you can easily find gaskets, I recall I made a number of them for mine.
Old 08-06-2013, 01:40 PM   #8
vectorit
What?
vectorit's Avatar
I just had mine rebuilt, and getting the gaskets and bearings was a non issue.
The gaskets you can get from rockauto.com, or most any good transmission parts houses can get them for you. The bearings are nothing special, just your average Timken brands work.
In my case, I replaced all the gaskets/seals and bearings with new ones sourced via mail order.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 08-06-2013, 02:19 PM   #9
MyDad'sTruck
Guys- I really appreciate the help. The only question I have now really has to do with the adaptor. I know they came in different lengths because mine is shorter than the one from the donor, but I assume the bolt pattern is the same?? The tip on rockauto is solid, thanks for that! Tomorrow I am taking the truck to a 4wheel specialist that did work on the truck years ago for their thoughts on swapping the t-cases; will keep you posted.
Old 08-07-2013, 09:17 AM   #10
Yukon Jack
Post Whore
Yukon Jack's Avatar
As you're replacing gaskets be sure to use thread sealant on the majority of the bolts. Most aren't blind.
Old 08-07-2013, 01:41 PM   #11
dieseldude4bt
It appears that in the posted pics, one of the cases is on a sm465 transmission and the other is on a sm420 trans, if so the adapters are not interchangeable.
63 k20 with cummins 4bt, owned sence 1982
dieseldude4bt is offline   Reply With Quote
Old 08-12-2013, 10:18 PM   #12
MyDad'sTruck
I know the adaptors are different, but the t-cases both have the same tag "Rockwell T 221" Wouldnt the new one bolt to my original?! The difference appears to be in length of the t-cases primarily; are the bolt patterns different, etc?
Old 08-13-2013, 09:53 AM   #13
dieseldude4bt
Yes the t-case should bolt to either adapter, but the other adapter won't bolt to your trans if it's off a sm465.
The transmission on the right looks like a sm420 in the pic.
Old 08-13-2013, 11:29 AM   #14
dieseldude4bt
After rereading the first post I see that you have the Sm465 in your truck, it appears that the second is a Sm420 from what I can see in the pic, sorry about the confusion.
The transfer case from the 420 should bolt to the 465 but the adapter (the piece between the trans and transfer case) won't interchange between the two transmissions.
