Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 07-24-2013, 12:13 PM   #1
mtully79
mtully79's Avatar
Oil pressure question
Oil pressure at near peak when I first start it up, then falls slowly over the course of 15-20 mins. It's only started doing it the last 2 or 3 trips after having on the road for the past 3 months. I only take her out on weekends around town, so she's not a daily driver. Any ideas?
mtully79 is offline   Reply With Quote
Old 07-24-2013, 01:00 PM   #2
jaros44sr
jaros44sr's Avatar
Re: Oil pressure question
May be just the viscousity of your elixior, since it is hot out now, maybe the ambiant temp. and engine temp. are affecting it....what weight oil are you using?
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 07-24-2013, 01:18 PM   #3
vegadesign
vegadesign's Avatar
sounds like the oil is heating up to quick
may need heavier oil depending on what your weather is like
what engine and setup do you have?
low viscocity oil will start to do that when its running for while because the heat thins it oil making it harder for the oil pump to pick it up
"its not a hobby, It's a Lifestyle"
bagged and soon to be bodied 70 longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=564028
vegadesign is offline   Reply With Quote
Old 07-24-2013, 03:32 PM   #4
mtully79
mtully79's Avatar
I'm running 10w-40 synthetic oil. I've got a 350 in there, temps have been higher here at the beach the past month as well. Truck is garage kept out of the sun, oil pressure shoots up as soon as I turn the key.
Old 07-24-2013, 04:27 PM   #5
vegadesign
vegadesign's Avatar
so im assuming its running about 45-60 psi at idle?
after about 15 min or so of driving around at higher rpms it drops down?
Old 07-24-2013, 09:04 PM   #6
mtully79
mtully79's Avatar
Yea it drops down to normal level after driving for 15 mins. Engine idles at 700 rpm.
Old 07-24-2013, 10:20 PM   #7
fast eddie1968
What is your concern to high when cold or to low when hot?
fast eddie1968 is offline   Reply With Quote
Old 07-25-2013, 09:12 AM   #8
mtully79
mtully79's Avatar
Concern is the needle is pinned high at startup. It's my first experience with driving the blazer and have no reference as to whether this is normal for the truck or a sign that something is wrong.
Old 07-25-2013, 11:23 AM   #9
vegadesign
vegadesign's Avatar
iv never had one pinned high at start, but if its showing a constant oil pressure later and its not knocking at start up i wouldnt worry about it
Old 07-25-2013, 12:00 PM   #10
mtully79
mtully79's Avatar
Ok, I'll keep an eye on it. Thanks for the response.
Old 07-26-2013, 10:17 AM   #11
fast eddie1968
My 72 pick up has factroy oil pressure gauge and it is exactly the same way pegs cold when up to temp it is right in the middle .I think the gauges only read to 60 psi and cold on a good motor with a stck pump its probally 65 psi
Old 07-26-2013, 10:59 AM   #12
magicoolbus
magicoolbus's Avatar
The factory oil pressure gauge is indeed a 60 psi unit, unless someone along the way swapped in an 80 psi one (found on larger trucks). The best thing to do if your worried is to get a calibrated oil pressure gauge and hook it up and see what psi's you are actually running. A fresh rebuild with tight oil clearances can easily be 60 to 80 psi.
JB from AZ
1969 Chevy Sub K10
1957 Chevy 3200
1962 VW Beetle
1957 Willys CJ5
magicoolbus is offline   Reply With Quote
Old 07-26-2013, 01:06 PM   #13
mtully79
mtully79's Avatar
Great info, I'll hook it up and see what it reads.
Old 07-16-2016, 12:03 PM   #14
JDSurge
Angry Re: Oil pressure question
Hello everyone. I need some help with my oil pressure port. I have a rear seal leaking and didn't want to take out the transmission right now so I used some Lucas rear seal to fix it. At about the same time, my distributor when out (changed almost every part in it and still didn't fire) so I bought a MSD street fire distributor and it fired right up.
My question is: I now have no oil pressure reading on my new gauge. I removed the oil pressure sending unit at the same time I installed the MSD and there was no oil at the port or in the line. Could the rear seal stop leak have clogged up the oil port at the rear top of the engine, next to the distributor? Or do I have the distributor on wrong or bought a wrong distributor? The gauge was working before all this started but I was reading some threads about the ring around the distributor sending oil to the top end and now I'm wondering if I bought the right distributor.
I have a 350ci out of a 1977 blazer with HEI distributor.
Thanks for any advice to fix this.
JDSURGE
ALso posted a new pic of my blazer with the top off finally. Unfortunately, I went out to a Rod Run party last night and it rained in it for about 20 mins. I hope it will dry out OK.
JDSurge is offline   Reply With Quote
