Leaving parking brake parts out of drum brakes?
Im just wondering(and I think I know the answer) would it be OK to take out the parking brake assembly out of the rear drum set up of a truck and leave it? My cables are shot and ive never nor will ever use them. The only reason Im wondering is because their locked in the "engaged" position so I cant get my drums back on. The truck is a 69 c20 and ho52 rear end. Id like to just take the two drum brake parts and the whole parking brake set up off the truck. Would this affect the normal braking use of the drums? I use my transmission for it not moving any way. Ive seen some pictures on here without them on but just want to cure my suspicion.
1969 Chevy c20(Miss Hackjob) |
Hybrid67
Re: Leaving parking brake parts out of drum brakes?
I took mine out years ago for a similar reason and it runs fine. The only down side I've found is that the self adjusters were somehow associated with it and you could pull the brake 3 or 4 times and it would adjust the shoes out the to proper position in the drums. Now I manually adjust them every now and then. Not sure about the technical answer of yes or no. Good question.
Keep em' Running! ![]() All show.....no go ![]() |
#3 | |
It's all just a manual pull system anyway. To get it working temporarily, why not pull on what's left of the cable on either side with vice grips, to get it to release? Posted via Mobile Device |
![]() Join Date: Oct 2009
If it were me, I'd fix the problem. Parking on an incline with the trans as your only roll prevention isn't the best idea. I rarely use mine, but when it's needed, it's needed. I recently redid my brakes completely and the ONE piece I could not locate was correct rear cables (72 c20 d60). But some of the places could rebuild what I had. Mine weren't bad so I redid them myself. Good to have when u need em. And required on some states to pass a safety inspection.
Hey thanks guys for the info and help. Up here in sd there's no inspections' basically if it can move its good
![]() Posted via Mobile Device
![]() Join Date: May 2013
you can do without it but I would fix it , its fairly easy , and could save your life , or your truck if your brakes go out , They should call them emergency brakes
I've used the emergency brake more than once when a master cyclinder went out.I;ve also seen more than one trans ruined because the E brake wasnt applied on an incline.
I'm not certain, but I think that some of the parking brake hardware shares the same mounting points as the otrher brake stuff and actually "stacks" on or under the other pieces. By removing the parking brake stuff, there might be some "slack" left in the system, allowing things to rattle or not function properly. I'm with the others. Get it fixed. Relying on the paking sprag in an auto tranny can be sketchy, as these have been known to break under load. Relying on leaving a truck in gear with a manual tranny is a little more reliable, but manulas can pop out too. I like the idea of having an "emergency brake" at my disposal should the hydraulic system take a total dump.
you cant do a bootleggers turn without a parking brake
1969 Custom 30 wrecker
X3! I would never run without a brake "backup" plan.
When your foot goes to the floor and you go to hit the emergency brake but find it's not there anymore, you'll be sorry... ![]()
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
#13 | |
#14 |
a big oak tree aint such a good backup plan
fact is if u r in a serious accident and your truck gets inspected YOU R SCREWED bigtime an dont plan on driving anytime soon not to mention the liability just sayin// bein lazy and not repairin things properly aint much of a plan
#15 | |
Everytime a brake line popped, the light would come on but the pedal still went to the floor. Even adding fluid to the "bad" chamber didn't help the pedal. Bad feeling for sure. |
#16 |
way back when they were emergency brakes till some lawyer decided that implied too much liability and they suddenly became parking brakes...
1970 short step c10 leaf spring 454 |
#17 |
I've had my light come on but the brakes were gone by the time it came on, I am very thankful I had an e brake... Happened on my 67 and my blazer with the light coming on and the brakes just disappeared. An e brake is an absolute must in my book
1995 s10 blazer 4.3 1967 c10 350/350 fleet short 1993 s10 blazer 4.3l 4l60 RIP 6/20/14 2000 mercury sable Thats a how I roll |
#18 | |
So, I think maybe sometimes if someone loses all their brakes (with a dual chamber MC setup), it could be because they either ignored prior problems, or weren't aware something was wrong already (they bought the truck like that and don't know any better) Posted via Mobile Device |
#19 | |
This can also happen when a line just ruptures from a rusty line too.
#20 | |
#21 | |
#22 |
Oh I hope you didn't think I ment both front and back, I thought we ment how fast the rear brakes could go out, both times I had fronts but didn't want to lay on them to skid, sorry for the confusion mister B
#23 |
Thanks guys for all the help. I will soon fix my ebrake issue when I order more parts from summit. I took a look last night an it didn't seem too difficult
#24 | |
