07-26-2013, 02:31 PM | #1 |
Is there more than 1 port on an L6 engine for a temp sending unit?
I'm hoping to keep the temperature idiot light in the fuel gauge working after I install my tach gauge cluster....
If there isn't another port, has anyone tried this some other way? |
07-26-2013, 03:07 PM | #2 |
Re: Is there more than 1 port on an L6 engine for a temp sending unit?
There are a number of usable ports on both heads that can be used for sending units. If it is a pipe plug... you can use it.
Mark Jesus is the Way! 2003 2500HD CCLB Duramax/Ali (Clifford) 2014 2SS/RS black on black Camaro (Betty) 2006 Pontiac SOLSTICE silver/black (Lula-Bell) 1970 C/10 Short Wide (Peggy) 1964 C/10 Short Step (Hambone) RIP Jimmy Hamilton Thank you for the trucks |
07-26-2013, 05:45 PM | #3 |
07-26-2013, 06:41 PM | #4 |
Oh...sorry. I miss read your title. If not, I have seen Rad.hose slice thingies that the tuner crowd uses for extra temp senders. Look on Fleebay
07-26-2013, 08:45 PM | #5 |
I have a thermostat housing off a later 292 that has two outlets, on for the bypass and the other for whatever. Look around, they are out there.
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
07-26-2013, 11:19 PM | #6 | |
Anyway it has a ~5/8" tap on the top for an input. Sorry, I can't reconfigure the pic. They used to upload OK.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 07-26-2013 at 11:30 PM. Reason: add jpeg |
07-27-2013, 08:42 AM | #7 | ||
07-27-2013, 11:30 AM | #8 |
If this is the part I need, then Autozone has fixed me up (although it's gonna look kinda funky with the sender sticking straight up....)
07-27-2013, 11:50 AM | #9 |
I assume you realize the sender will be on the wrong side of the thermostat. I guess it doesn't really matter since the idiot light will be only a backup.
FWIW my old 250 had the sending unit screwed into the left side of the head. |
07-27-2013, 12:41 PM | #10 | |
The sending unit on my 250 is also screwed into the left side of the head (intake/exhaust side). |
07-27-2013, 07:26 PM | #11 | |
But does your upper radiator hose port [~2" dia.] angle to the rear? I think they're usually forward. Mine angles rear too. I use a flex hose rather than the OEM elbow-shaped formed hose. The 250 water pump is different, having one less outlet, but the thermostat housing is the same.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 07-27-2013 at 07:31 PM. |
07-27-2013, 07:37 PM | #12 | |
07-28-2013, 01:07 AM | #13 |
I swapped this onto my 250. Already drilled and tapped from GM. I don't know which I6 it came from.
07-28-2013, 01:17 AM | #14 |
That would be typical of a later (I don't know when they switched) 292. That is for the by-pass hose. On the earlier 292's, this was a much bigger hose, like 1.25" IIRC. The one I mentioned in a earlier post is like that, but it has 2 outlets on the drivers side, and one for the heater on the other side. I could take a picture of it tomorrow. I got it off a later square-body with a 292 not too long ago.
07-28-2013, 01:19 AM | #15 |
Some of trucks with 8V92s we work on have multiple sending units in one port. I'tll be a short straight pipe with a three port brass fitting.
We call it a tree and it isn't unusual to have temp, pressure, and a sending unit for a piece of test equipment out of the same hole in the block. |
07-28-2013, 11:26 AM | #16 |
