07-27-2013, 12:59 PM | #1 |
Another AC question?
I recently had my AC charged up, new compressor, all new lines, and I found a local shop with some R12 to charge it. The AC works and is ice cold, but if I drive for about an hour or so with it on, it starts to get a little warm inside the truck. I opened the hood when I got home, and the big return line had a good layer of frost/ice on it. By looking at the water flowing from my ac/heater box shortly after, I'm getting the part inside there was frozen as well?
Any ideas what it is before I bring it back to the guy? Thanks
Mark 71 C10 Cheyenne 12 Aprilia RSV4 |
07-27-2013, 01:44 PM | #2 |
Re: Another AC question?
Low of freon or the expansion cable/metering device is bad
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
07-27-2013, 04:29 PM | #3 |
2x
Mark Jesus is the Way! 2003 2500HD CCLB Duramax/Ali (Clifford) 2014 2SS/RS black on black Camaro (Betty) 2006 Pontiac SOLSTICE silver/black (Lula-Bell) 1970 C/10 Short Wide (Peggy) 1964 C/10 Short Step (Hambone) RIP Jimmy Hamilton Thank you for the trucks |
07-27-2013, 09:38 PM | #4 |
Who Changed This?
Possibly the POA valve may be sticky and needs attention. An alternative is to temper the AC with a little heat to melt the ice. You can do that with a little move of the heat lever. If it's ice cold, dialing in a little heat could do the trick, and won't drive you out of the cab. Look at the view port on the receiver-dryer to see if there are any bubbles. If there are no bubbles, you likely still have a full charge. I have seen this on brand new cars and trucks, when I worked for a Chevrolet (well, actually two different ones) dealer in the early '70s.
